Question about Canon FAX-L350 Plain Paper Laser
Getting G3 001 error code, 00C9 error during transmission. Phone lines are good what next?
  • Canon tech CROATIA
    Canon tech CROATIA May 11, 2010
    try send fax to a different numbers if not good try Data registration then # clear all
FAX ERROR 410
Code 410: During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
HP Recommendation: Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
May 26, 2015 | Office Equipment & Supplies
Communication error message occurred during transmission. upper cornr has error code b52
This sounds like a fax error, such as the phone line dropped, the remote system hung up. or something like that.
May 19, 2015 | Epson WorkForce Pro WP-4540 Color Ink-jet
How to disable ECM and Reduce Baud rate for Canon MF4270 G3 Fax ?
Your approach is correct however it doesn't look like the MF4270 provides for these settings. One might expect to be able to select G3 or ECM or set a lower TX speed.
I located the settings for different Canon Fax machines here:
VoIP Fax Settings
Jul 25, 2014 | Canon imageCLASS MF4270 All-In-One Laser...
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
Problem faxing-error message
Error 388:
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Error 403:
Definition
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
May 29, 2009 | HP Office Equipment & Supplies
Why am I getting this message? Error 402 fax machine. HP Officejet J3680
Error Code: 402
Definition
Solutions
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 30, 2009 | HP J3680 Officejet All In One Printer
Machine won't fax
The error code indicates a problem with either the phone line or the fax format that is not supported by HP Photosmart C6180. For more information go to the link below:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02549&lc=en&dlc=en&cc=us&lang=en&rule=25901&product=1153494#Error420
Apr 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
E100 error
Hi Paikin,
The error code 100 - Excessive Repeat Protocol during Transmission. Causes
1. Poor line condition.
2. Low transmission level.
3. Echo on the line.
Try reducing transmission spped.
Rgs
S88
Dec 18, 2008 | Canon LaserCLASS Fax 710 Printer
1990 nissan maxima automatic transmission
I suggest this is the Vechicle Revolution Sensor is causing the problem.
Run Diagnostic on the Transmission and review error codes.
An error (1) Code would confirm this.
If no error code exists then the problem is the band needs tightening. The gear to slip is always 2nd gear in this vechicle first then other latter as the problem becomes worse. There is only one band in the transmission and it is fairly simply procedure to complete but you need 1-10nm Torque wrench and to remove the valve body to get access. Don't attempt if you don't have good mechanical skill or have exp. on motorbike or other auto transmissions.
Jun 21, 2008 | 1990 Nissan Maxima
Error code
Hi Mike,
The error message "A communication error has occurred during the fax transmission" normally indicates that for some reason the fax call was interrupted or there was some interference on the telephone line during the fax transmission. Some possible interruption/interference on transmission(s) are:
1. the telephone line is not a dedicated fax line - there could be an extension which was inadvertently lifted/used during a fax call;
2. noisy/dirty telephone/fax line - corrosion on the terminal, joints, connectors, pins, plugs, jacks, telephone outlet or even on the provider's system. This could be determined by using the handset of the fax machine, dialing a single digit (to make the dialtone disappear) and listening to the phone's earpiece. There should be no crackling sound or static but a clean/dead air. In some cases where the telephone/fax line is shared with the DSL, then it could be the filter/splitter used;
3. some phone lines can still accept an incoming even though in use (call waiting) - the ringing of the 2nd call is more than enough interruption/interference;
4. RFI (radio frequency interference) - an electronic device that transmits a radio signal such as a two way radio, a WiFi router or mobile phone; and/or
5. noisy/dirty power AC mains -the outlet/AC power line where the fax device is plugged in has some other appliances/devices that draws power from it that can cause static/transients/spikes along the power line. Examples are water dispensers with built-in cooler/heater, dehumidifier, aircons, refrigerators and any other that switches itself on/off. A simple solution would be to use a different outlet and/or use a surge suppressor.
As to the "error code number 321*", pls post back the make and model of your fax device. Alternately, you can reference this site. If your fax machine/device is an HP brand (and/or the receiving end's fax machine is), pls check this link.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Office Equipment & Supplies
Canon FAX-L350 Plain Paper Laser Logo
635 people viewed this question
old marine
old marine
