Question about Dryers
No heat electric dryer
Frigidaire Electric Dryer model # fde437ghs0
My dryer turns, blows , but does not heat up, thus does not dry my clothes.
I was told I need a new terminal block kit would replacing this solve my problem ? The block must gotten damaged during my recent move , because dryer worked just fine prior to move. I just wanna make sure that replacing the terminal block will solve my problem. The block propblem was pointed out to me by a repairman the wires are all messed up and the block is not really secure with in the unit , but obviously it gets power just no heat .
  • bigford Feb 25, 2008
    Yes getting confirmation on the fact that the terminal block could indeed be the reason I'm not getting any heat gave me the go ahead to buy the part , and replace it myself. I just went ahead and replace the power cord also took me ABOUT 20 MINUTES TO RE-INSTALL THE NEW BLOCK ,THANK YOU VERY MUCH..
    Master:
  • 619 Answers
Hi , what the repairman say is true , that parts are available in appliance store or any electrical shop., bring that sample to the appliance store for sample . that is like sensor it will open when it broken the filament of heating unit will not heat up if that parts will open., it is one one who limit the heating allowed by machine .
Posted on Feb 21, 2008
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
The heating element works but no hot air blows so it takes 2 hours or more to dry a load of clothes.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 06, 2011 | Frigidaire Electric Dryer
My drying is not sending hot heat to dry the clothing what should i do
heatman101
Apr 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
My dryer will not dry it gets hot but does not dry clothes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 25, 2010 | Frigidaire FEQ332E Electric Dryer
My dryer is making too much noise and it's not even drying up clothes.
Hi
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 12, 2010 | Frigidaire FER311FS Electric Dryer
Have a frigidaire "gallery" series stackable washer/dryer, the heating element initially turns on when the dryer starts. you can see the element light up and feel heat but after a minute of run time the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire Dryers
Frigidaire Gas Dryer, won't heat to dry clothes, we have cleaned the vents , were full, now clear, why won't it heat up. Gas turns on drum turns.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
Aug 10, 2010 | Frigidaire AGQ6000ES Gas Dryer
Our dryer is a model # fer641fso. it is notgetting the clothes dry without running 2 or tree cycles. the dryer is very hot to the touch in the back and very warm on top. the vent is hooked up properly. any...
u have a clogged vent,,, undo vent to dryer run a load if heats faster then replace dryer vent, and clean out ur ducting with a leaf blower blow that ducting lint outside.
Feb 03, 2010 | Frigidaire FER641FS Electric Dryer
My electric frigidaire dryer has stopped turning and will over heat. what could be the problem?
The belt driveing the drum has probably broken. The tumble action is essential to proper and safe drying of clothing. It will need to be replaced.
Nov 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Dryers Logo
139 people viewed this question
Top Dryers Experts
