Question about Zanussi TC7102W Electric Dryer
Replace wire terminal
Please help. do you have a diagram of how to replace wiring terminal for whirlpool dryers that goes on the thermostat located on the heating element. one side of the tip is broken
  • 958 Answers
Normally, if you have a broken thermostat, the wires would just be lying around there. all you have to do is put it back on a new pc of thermostat.
Posted on Feb 21, 2008
Need to know how make sure that I have replaced the 4 prong cord with a 3 prong cord corruptly. I am specially concerned about the ground connection. I would like to get step by step instructions and a...
4 wires goes as such with oldtech2332.jpgthe red wire going on the right side,the black wire going on the left,the white wire goes on the center terminal. Now what exactly do you do with the green wires is what your asking yourself. It goes onto the cabinet after removing that little link that went from the center terminal that was beweeen the cabinet and and the white wire terminal.Yes remove that link and install the green wire where that link was just attached to a minute ago.
Aug 16, 2011 | Whirlpool Dryers
My whirlpool gold electric dryer model # GEX9868J ,stopped drying it just blows cold air , can you please tell me what the problem is .
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
Aug 09, 2010 | Whirlpool GEX9868J Electric Dryer
ELECTRIC DRYER, RUNS NO HEAT WHIRLPOOL LEQ8000JQ3
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Please rate me, Thank you
May 09, 2010 | Dryers
Whirlpool electric dryer does not heat, everything else run ok.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the safety of overheat from the machine.
I will include these two websites for parts and further help:
Good Luck,
Hope this helps
Please rate me,
Thank you
Dec 07, 2009 | Dryers
My whirlpool lg4634jq2 recently caught fire, then a 3 days later it stopped heating. It turns on and spins, however it will not get hoe. Please help
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
Oct 19, 2009 | Whirlpool LGR4634J Gas Dryer
How do I get to the thermal fuse on Whirlpool electric dryer LER4634EQ0
All the heating and temperature control components are located in the back of the dryer. To access, unplug the dryer and remove the exhaust vent hose. Turn the the dryer around so you can view the back and remove the back panel. With the panel removed, the component locations are as follows:
Right-Hand Side:
1. Heating element - located inside the heater box. If bad, the dryer will run, but will not heat. A good reading is about 9 to 13 ohms.
2. Thermal Cut-Out (TCO) - located on the outside of the heater box on the end opposite the heating element terminals. If bad, the dryer will run, but will not heat. A good reading is a short (0 ohms).
3. Hi-Limit Thermostat - located on the outside of the heater box adjacent to the heating element terminals. It works in conjunction with the TCO to help regulate the drum internal temperature. A good reading is a short (0 ohms).
NOTE: If either the TCO or Hi-Limit Thermostat are found to be defective, it is recommended that you replace BOTH components to prevent premature failure. These two components are commonly sold as a set.
Left-Hand Side:
1. Thermal Fuse - located on the blower fan housing. It is a small white plastic looking component with two wires attached. If defective, the dryer will not run at all. If the component is good it should read a short (0 ohms).
2. Internal Bias Thermostat - located on the blower fan housing adjacent to the Thermal Fuse. It has four wires attached to it.
NOTE: All resistance checks should be performed with the component terminal wires disconnected to prevent false readings.
If you have any questions, you can refer to searspartsdirect.com for some helpful exploded view diagrams to assist you. The components I mention are listed under the "Bulkhead" heading as follows:
Item 6 - TCO/Hi-Limit Thermostat replacement kit
Item 15 - Hi-Limit Thermostat sold separately
Item 17 - Heating Element
Item 23 - Thermal Fuse
Item 24 - Internal Bias Thermostat
If you need further assistance, please let me know. I hope this helps you.
Sep 23, 2009 | Dryers
Model # LHE 7800 W1 On the thermostat by the heating element Which terminal does the red wire go on?
On a/c voltage , if you have 2 terminals on a part , it won't matter which terminal the wire goes on . There are several red wires in that area ,so if it goes to the thermostat , it doesn't matter which terminal on the thermostat it goes on .
Jul 13, 2009 | Whirlpool Dryers
Wire hookup
Hi, if you are talking about thewire on element and thermal stat, the element terminals are usually wider then the thermal stat. Does this help? Please let me know. I cam try and get a wiring diagram with a model #.
Vic
May 22, 2009 | Dryers
I have an electric whirlpool dryer and had to buy a new heating element the problem is that I don't have a clue what wires go where. I have 2 red wires and an orange one but I'm not sure which ones hook to...
small orange goes to small terminal on hi limit thermostat you'll find only one of the red wires will fit the terminal on element it is slightly bigger than terminal on hi limit
Jun 05, 2008 | Whirlpool Dryers
Zanussi TC7102W Electric Dryer Logo
126 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Marvin
Marvin
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
