Question about Sony KP-53S25 53" Rear Projection Television
Where is the fuse located on a KP53S25 Sony TV?
HI MY TV SONY KP-53S25 REAR PROJECTION TV HAS NO PICTURE AFTER TURNED ON. THE LIGHT ON POWER SWITCH BLINKS RED AND KEEPS BLINKING. NO PICTURE IS EVER SHOWN. DO YOU KNOW WHAT IT COULD BE? THANKS
Posted on Aug 31, 2010
  • Sony Master
  • 1,527 Answers
Hello there should be a glass fuse in the power supply also beware in a lot of sony sets there are soldered in fuses aswell. and circuit protectors i hope it helps
regards
shaun
Posted on Feb 06, 2010
Trying to locate the thermal fuse on my kf50we610 sony tv
hi,
Which theramal fuse you are trying to locate. If you need the service manual then i will st it to you. For that i need you eamil id. Not able to sent the same by fixya. Because its a pdf file. It will help you to find out the fuse for which you are serching.
OK
Aug 23, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
I have a sony 50 inch Hdtv (KDF E50A10) the power/standby ligt is red and blanking 6 times. there is no picture or sound on from the TV. do you know what could be wrong with it. Thank you
One of two things:
Either door lamp sensor...
Or thermal fuse located above the bulb's housing.
This tv is known to not turn on for these two reasons.
The thermal fuse looks like this:
drewpalmer04_73.jpgThe door lamp sensor is located where the door comes in contact with the tv housing. You can't miss it!
Thank you and good luck!
May 16, 2011 | Sony Televison & Video
No Power Problem with KV-27s15 Sony TV
Barry, remove the back cover by removing the screws with an arrow next to them. The fuse is located on the left side as viewed from the back, where the power cord connects to the circuit board.
Aug 09, 2009 | Sony KV-27S15 27" TV
Where is the thermal fuse locates in the sony KDF-e60A20?
Hi, the thermal fuse i located right next to the lamp is actually mounted on the lamp casing, deep inside the tv, you will need to disassemble the tv in order for you to get to it, if don't have any skill is better that you call the repairman and you are looking at $250.00 repair.
good luck
Jun 22, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony KP53S25 rear projection TV - Horizontal lines on display
try this link
see this link and try to understand the blink codes.
this will surely help you
May 31, 2009 | Philips 60PP9202 60" Rear Projection...
Help with my sony tv
The thermal fuse is located close to the front of the set just to the right of center, looking from the rear of the TV. Mounted near the lamp. Part# 191002393. Once you have the new part, it should not be difficult to find it in the set.
May 16, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 53 inch projection screen with hourglass picture
If you are familiar with TV repair, have electronics basic knowledge, good soldering skills and tools then check dry (cold) soldering joints at D board of this TV. Resold all lose connections there and check picture.
Still no joy then you need to replace D board.
Feb 25, 2009 | Philips 60PP9202 60" Rear Projection...
Had power surge? When plugging in or turning on the unit I hear clicking. No picture.
Mine had the continuous blinking , and sometimes 2 blinks after trying to turn it on again. I was given the tv and after checking it out found two blown T3.15 amp glass fuses on the audio amp. T for time delay. I went to a recycle center and bought two complete chassis for my model kp53s25. I started changing the standby power supply first. Still did the same thing. I changed the high voltage board with the smaller transformer only and leaving the other larger high voltage transformer in the set. I just cut and spliced the single connecting high voltage line between the two high voltage transformers. Still had the same problem. I change the audio board and the set would work until I believe the audio board heated up or had an intermitant short and the tv would shut down. I replaced the full audio board with another and now the tv stays on and is working great. There seems to be a overheating problem with the sony audio board and i may buy a muffin fan to fit over the audio boards large heat sinks for added cooling in the rear right hand corner of the tv . Touching the heat sinks after tv has been on a while is very warm. Find a recycle center as I bought the parts I needed for 10 dollars for two complete chassis. I should have keep the color projection tubes.
Nov 17, 2006 | Sony KP-46S25 TV
Sony KP53S25
your problem is a defect with the b+ going to the crt driver transistors such as a capacitor off the High voltage tranformer or could be a coil or resistor that changed value in the filiment curcuit. This is another hard one to say without more info. if yuo dont do any troubleshooting or dont have the know how then Im thinking its best that you call a pro.. Good Luck
May 03, 2006 | Sony KP-53S25 53" Rear Projection...
Open Questions:
See all Sony KP-53S25 53" Rear Projection Television Questions
Televison & Video Logo
242 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
