Need audio device - Office Equipment & Supplies
  • 5,138 Answers
Call Encompass Parts Distrubtion 1-800-638-3328 or Visit their WEBSITE.
Posted on Feb 12, 2010
No audio output device is installed
That statement might be true. The audio output device is hardware. If the hardware is present, go to control panel, hardware and sound, sound, audio devices... look for audio hardware, At that point, I like to delete any devices, then go to actions, search for new hardware. If found, windows will usually know what drivers the devices need. On some PCs you need to have a driver disk with special drivers If no hardware is found, you need to go to a PC repair shop or buy a book on PC maintenance and repair...I like the book, others like the repair shops, your choice.
Oct 27, 2014 | Computers & Internet
I have no sound at all, not sure wot to do. says something about no audio devices are installed,
hello jenz8860, try open device manager (run type devmgmt.msc), if u find question mark on your audio device then u need to install audio driver.
to install audio driver use motherboard driver, insert to CDROM, right click the audio device on device manager then update driver. choose recommended option then click next and follow the instruction. your audio device will automatically installed. if it success installed then u need to restart your PC.
if there is no problem in device manager, high possibility it's on hardware problem, try to see cable connection between speaker and PC (use back panel connection, don't use front panel audio, this to make sure the connection is good), if it's ok then mostly problem came from your speaker. try to use another speaker.
hope this useful, regards.
Aug 26, 2011 | Audio Players & Recorders
We can not find sound device in this computer, we want to install sound can you help us
Yes we can help you.
To locate if there are sound device in your computer.
1. Go in control Pannel
2. Double click sound and audio device.
3.Click on the audio TAB and you will find the default audio device.
If there are no audio device, you wiil see the same in fade mode.
that there are no audio device present on the machine.
Physically you will need to check on the computer if there are sound card.
Sometimes audio device are present and are disable in the bios.
11bd5df.jpegI
IF NO SOUND DEVICE ARE PRESENT YOU WILL NEED TO BUY SOUND CARD THAT CAN BE PUT IN PCI SLOT IN THE COMPUTER.
Also there are usb sound card device more easily and praticall to buy and intall and to use.
We hope you got and idea of sound device.
If you need any further help or suggestion do not hesitate to revert back.
Thanks
Regards
uttam
Jun 08, 2010 | Computers & Internet
No audio device
The "No Audio Device Error" message is usually displayed by your computer when it does not detect any properly working audio device attached to it. You will not hear any sound from your computer when this message appears. Only the internal speaker of the computer can provide you bleeping sounds.
When this message appears on your screen, you will need to first check your computer's BIOS and ensure that the audio is set to "auto" mode. You should also check if you have installed the correct drivers needed by the audio device attached to your computer in order for it to work properly.
Audio Device Drivers The most frequent cause of this problem is an incorrect audio device driver that has been installed by the user. In order to double check if your driver matches your device, refer to the user's manual that came with it to look for its type and specifications. The audio device driver for an onboard device should be provided along with the chipset drivers in the CD that accompanies the motherboard.
Use the Device Manager You can use the device manager to ascertain if the audio device drivers are installed properly. To go to the device manager, right click on the My Computer icon, then click Properties, click on the Hardware tab and then Device Manager. If any device is marked with a yellow question mark, it is an indication that the required drivers are missing. It should be instantly clear if the audio device is truant.
Loose Connections on the Motherboard You can open your computer and directly look at the information written on the audio device itself. While doing this, make it a point to check all connections by ensuring that everything is properly plugged in its correct place. Sometimes, this error is also caused by loose connections and a sound card that has been improperly attached to the PC.
You can download the latest updated drivers from the manufacturer's website, either from your own computer or another. If you have used another computer, you can use a data storage device to bring the drivers to your machine and execute the software installer from there. Ensure that the driver you have downloaded is compatible with the operating system installed on your machine.
Is Your Audio Device Defective? If problems with your audio device still persist, you can opt to test the audio device on a different machine just to see if it's in good working condition. If it still doesn't work on a different machine, you have a defective audio device. You will need to get it replaced if it is under warranty or purchase a brand new one. Remember that you should buy the audio device that is compatible with your motherboard. In addition, don't forget to ask for the updated software drivers of the audio device
May 18, 2010 | Computers & Internet
I need a audio device fpr my pentium 4 with windows 2002 SP2
In most cases audio device problems are related to device drivers. Try (re)installing the right audio driver first.
http://www.pcauthorities.com/pc-errors/no-audio-device-in-windows
Dec 27, 2009 | Intel Pentium 4 2.40GHz 512/400/1.5V...
I use to have audio device. but now theres
If you are using XP you need to right click on the my computer icon and then go to manage. Once the window opens up select device manager. This screen will show you all the devices on the computer. Check audio if you see once of the devices with a yellow question mark that means the computer can see your audio device but it does not know how to talk to it. In that case you will need to find the audio disk it came with and re-install the driver or you can go to the manafactures web site and find the driver for the audio device.
Good luck
Proteus
Nov 21, 2009 | Computers & Internet
NO AUDIO-MULTIMEDIA CONTROLLER
You need to install the audio driver of the board. Your board should come with a disc if not. go to ASUS website and downlaod the driver for your audio.
Hope this helps.
Oct 03, 2008 | ASUS P4S800-MX Motherboard
NO AUDIO DEVICE
You need to install the drivers for the audio device.
Go here, download and install the driver.
Then it should work.
Suc6
Mar 27, 2008 | Sony VAIO VGN-S150 Notebook
Audio Devices
You need to remove device from device manager and to install back audio driver
Mar 05, 2008 | Compaq Presario 5000 PC Desktop
Sound card not detected
The yello esclamation mark signifys you need up dated drivers then it will go again.
Sep 14, 2007 | Ensoniq (6000708) Sound Card
12 people viewed this question
k24674
jasbo
jasbo
