Question about Microwave Ovens
Recently the light flickers and gets dimmer, then back to normal, several times while heating something in the oven Just wondered if this is some simple thing to take care of, or should we consider replacing the oven? It was manufactured oct 1998, sn 810km00798, model # MA-782M
    Brigadier General:
  • 4,088 Answers
Sounds like an arcing switch or connection, or maybe the light itself is not making a good connection. Check the plug in the outlet socket to see if it gets hot after heating something. Wiggle the cord to see if the light flickers. The door switch is a microswitch type and should make a positive 'click' when operated.
Posted on Feb 05, 2010
When it is running the lights flicker or go dimmer or trips a breaker.
you have too much wattage on the same circuit. microwaves draw 1000-1100 watts typically, something else in on the same circuit drawing another 700+watts and tripping the circuit breaker. lights, refrigerator, stove, fan, hair dryer, etc, etc. if you turn everything else off and you have the same issue, then you may have an electrical issue with your wiring and it could be a potential shorting/fire issue. be cautious, be smart.
Jul 23, 2015 | Microwave Ovens
How do you change the bulb inside this microwave oven
Most of the ovens have a fan vent which can be removed, normally the bulb can be accessed through that area. Hope it helps.
Jul 17, 2015 | Microwave Ovens
What to do when oven smells like burning plastic
new ovens do have a certian amount of "burn in" to do when there new best to heat up and cool off oven several times before actuall food use to remove any construction solvents and "cure" all the materials inside
also ck to make sure you removed all the shipping packing sometimes this gets left inside by accedent and smells something horrible when heated ( caution :: Foam degrades to cyanide deadly gas when heated!!!!)
Sep 08, 2014 | Microwave Ovens
Our Kenmore microwave oven recently stopped heating. The lights, turning plate and controls all work but with no cooking is occurring. The last time I attempted to heat something up I heard a cracking...
The most likely cause is a bad magnetron, "heats food" the other two possibilities are the high voltage capacitor and diode. The cost to repair will a approach a new microwave oven.
Apr 08, 2011 | Kenmore 80412 Microwave Oven
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
My whirpool oven is working but does not seem to be heating as it should I wonder if the fan is not working
magnetron do get week over time even more so if you do a lot of short time food reheat, the fan normally is used to cool the magnetron wave guide and if it stops working the over temp safety will trip and stop the magnetron from working
Apr 27, 2010 | Whirlpool MH1150XM Convection/Microwave...
New GE coffee maker #169209 (1300 watt) 12 cup digital. House lights flicker when in hot plate warming mode. Tried on 15 amp GFI circuit and then on dedicated 30 amp #10 wired circuit -- but same...
Hi, then it might be a factory fault problem, i will advise you to call in a electrician to come and witness it whenever you put it on so that he will be able to identify weather it is the microwave's fault or an electrical fault...
Mar 11, 2010 | Microwave Ovens
Fan stopped running while heating something up
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uyiu4
Mar 17, 2009 | Amana ACO1860 Microwave Oven
Microwave Ovens Logo
79 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
