Question about RTO Sno Wovel wheeled snow shovel
Snow blower wont start
I bought this snow blower 5 yrs ago and used it 3 times since then and i cant get it to run i have checked the carburater fuel line primer chock and the spark plug and it still wont start
    President:
  • 2,030 Answers
Carb is probably gummed up from old fuel..take it off then clean it good and i bet it fires up
Posted on Feb 05, 2010
Bought last year can not start
Is it new gas you are using? If you left the gas in from last year you may have a gummed up carburater. If you have a fuel cup on the bottom of the carb take it off and clean it up also cleaning the fuel jet as well. If the jet is dirty it will not run. When you remove the cup be careful the float does not come down too far or the gadget that the float works may fall out.
Jan 19, 2016 | Garden
Start snow blower runs for 3 min. and starts to over heat checked oil its ok then stats to shut down like its not geting oil
Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
Mar 01, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Start and runs for 3 min then stop
Try running it with a loose fuel cap. If it now runs fine find and clear the vent hole in the cap.
Jan 21, 2014 | Tecumseh 5hp Engine Snow King Mtd Blowers...
How to start my snowblower model #247 886911
check gas and oil
put full thottle
full choke
prime 3 times
pull cord or electric start
repeat if doesnt start
Dec 25, 2012 | Craftsman Snow Blower / Snowblower Bottom...
I have a mtd 3.5hp 21" snow blower it was bought new in 11/06 the problem im having is stalling it starts ok some times other times it stalls and won't run others it will only run at full choke if...
Try running some fuel system cleaner through it. A good choice is Chem Tools Berryman B-12. There are some hardworking solvents in the product that could help you overcome a dirty carburetor. Initially use a good, strong dose. Maybe double what they recommend . (1 oz/gallon). If this doesn't work, the carb will probably need to be removed and inspected and cleaned.
Feb 03, 2011 | Garden
I have a Yard Machine 5.5hp 2-stage snow blower. I bought it used but I think it is a lightly used 2004+-. I use the primer bulb and it will start within 2 pulls, runs beautifully. I slowly open the...
The running time seems to indicate a plugged fuel tank vent. Try opening the cap to see if that will allow continued running. Many engines have the vent within the cap itself, while others vent from the air cleaner through a line. Ignore the fuel drip on the adjustment screw. Hope this helps!
Dec 27, 2010 | Garden
I bought a used dynamark 3/20" snowblower, when i
1. Is there gas in the tank?
2. Is there a fuel line valve, either as part of the carburetor or between the fuel tank and the carb?
Dec 21, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
I have Ariens Model # 1336DLE snow blower aprox 5 yrs
A volt meter or test light will be needed. Also a 12 volt battery supply ( you can use an automobile battery or your automobile)
*Please Note: before testing, make sure all wires and connections are tight and not corroded, loose, or burnt. Many electrical problems are just loose, broken, or burnt wire connections.
Test the chute rotator motor: you will need to disconnect the motor from the wiring harness.
1) connect a wire to the 12 volt supply and one of the motor leads
connect the other wire to the remaining lead
*note: positive or negative does not matter, because the chute motor will rotate either direction, and by reversing leads, the motor direction will reverse.
2) If the motor is good, now check for voltage from the snowblower engine.
Locate the supply wire to the rotator switch, with the engine running, check the voltage reading on that supply wire.
3) If the supply is good, then the switch is bad
Nov 15, 2009 | Ariens Garden
10 yr old mower, has not been started for 3 or 4 yrs, won't start
Remove the fuel filter and fuel line and replace then try it, if it still does not stay running you will have to change outthe primer bulb. If you need more innformation let me know. Aslo please rate this as this is a free service and thanks for using Fixya.
Aug 18, 2009 | Toro Lawn Mower With Toro Power Tools
RTO Sno Wovel wheeled snow shovel Logo
237 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
