Question about Gateway 7200X PC Desktop
How to open the case to upgrade rams - Gateway 7200X PC Desktop
    Problem Solver:
  • 7 Answers
Alert: Before working inside a computer, disconnect all the cables from the back of the computer and make sure you're aware of the potential dangers of ElectroStatic Discharge (ESD).
Unfortunately, there is no standard for how to open a computer case, which means how you open your case depends on the manufacturer of your case and/or computer. Below are the three most common methods of how to open a computer case.
Before opening the case, disconnect all the cables from the back of the computer and place it on a table. Next, identify the type of chassis you're working with. Below is a short list of different types of ways a computer case cover is held on.
  1. Screw - Case held on with screws.
  2. Thumbscrew - Case with screws that require no special tools and can be tightened and loosened with your fingers. Often, these screws also have indents that allow them to also work with tools if needed.
  3. Screwless - Case that has no type of screws, only held on with metal or plastic clamps that can release from the case by pressing buttons or switches.
Screw / Thumbscrew computer cases
The screws, buttons, or other mechanisms to open a computer case are almost always located on the back edges of a computer. If the case has screws, these will need to be removed before the case cover can be removed.
Note: Often, the power supply screws are also visible from the back of the computer; however, these are often in the middle of the back of the computer case. The screws you want to remove to open the case are always on the outer-edges of the back of the computer.
Once screws have been removed from the back of the case, push the side cover of the computer case towards the back of the computer. Either the side of the computer case will slide off, or the complete cover will be removed.
Note: If you've removed a side of the computer but cannot see the inside of the computer, it's likely the wrong side of the computer case was removed; simply remove the other side to expose the inside of the computer.
Finally, some computer cases use a combination of thumbscrews and screwless mechanisms to hold on the side of a computer case. If you only needed to remove one on the back of the computer, it's likely you're working with this type of case.
Screwless computer cases
There are several techniques on how computer and case manufacturers develop a screwless entry chassis. Therefore, keep in mind that the below steps may not apply to your computer case.
As mentioned earlier, screwless computer cases work by using buttons, levers, or push arms. For example, NEC, Dell, and other major computer manufacturers used a popular screwless entry case where a single thumbscrew is removed from the back right side of the computer case, and while the computer is on its side, press and hold in two small levers on the top and bottom and push the side towards the back of the case.
In addition to the above example, a screwless computer case may have similar levers that may be located in other locations such as the bottom of the computer case or the front of the computer.
Finally, there are also several other screwless computer cases that utilize buttons often located on the front bottom portion of the computer case. Simply pressing this button will release the side of the case, allowing it to be removed.
Posted on Feb 10, 2010
  • Gateway Master
  • 5,660 Answers
Look at the back of your computer.
There is a large green thumbscrew on the left outside edge. Unscrew it to loosen it. The screw does not come out all the way.
If there is a sticker that wraps around the side cover to the back, you can cut through it. (Silvery sticker with holes in it)
This sticker came from the factory. It was used to see if the computer had been opened by the user, which would void the warranty.
Since this computer was made in 2004, the warranty is long gone.
Now you will see a Black Lever. The lever pivots.
Pull up on the bottom, and the side case cover will pop open a little.
Ease the side cover out to about a 30 degree angle, and lift it straight up.
When you go to replace the side cover, DO NOT use the Black lever. (Not shouting)
Just line the tabs at the bottom of the cover in the slots at the bottom of the computer case, and ease the cover closed.
When the cover touches the side of the computer, you have to push it a little harder. Then it will snap into place.
How do I know this? I'm using a Gateway 7200X right now.
Additionally.
Before you open the computer case, unplug the computer from power. Unplug the power cable FROM the surge protector, and NOT the back of the power supply.
Unplugging from the back of the power supply, while the power cable is still plugged into the surge protector, may cause a Voltage Spike.
Result is that the Power Supply could burn out. It can also burn out the Motherboard, Processor, Ram Memory, and Graphics Card.
(If this is the original hardware inside your computer, there is a chance that you have an ATI Radeon X600XT graphics card, like I do. It's in a PCI-Express x16 slot)
Many have stated, that they have unplugged the power cord from the power supply, while the power cord is plugged into the surge protector.
They also eventually come back, and state they burned they're computer up.
BEFORE you reach inside your computer, and BEFORE you take that/those new ram sticks out of their protective anti-static bag/s, TOUCH the metal frame of the computer case. (Not shouting)
(Computer unplugged from power)
This will relieve your body of Static electricity.
Static will fry out, (Short Circuit), the hardware components inside your computer.
Computer unplugged from power, you are safe.
Touch the metal frame of the open computer case, your computer is safe.
IF, you get up, walk away, then return, Touch the metal frame again.
Work on a table. IF, you have carpeted floors, refrain from swinging your feet back, and forth. Creates static.
Refrain from touching the gold plated contact pins on the bottom of the ram stick. You can hold it anywhere else, as the main body is coated with a see-through plastic.
For ease of removing ram memory, and installing, I like to lay the computer down on it's side, open part up.
I use a clean towel on the table to lay the computer down on, to keep from scratching the table, and the computer case.
It is also a good idea to remove all cables from the computer when doing so. You may want to make notes, and a drawing, as to where the cables go if you are not familiar with their placement.
If you have twin satellite speakers, and a subwoofer like I do, there is a special placement for those speaker cables. Advise Do Not mix them up.
The ram memory slots have locks. One on each end of the slot. They are white in color, and look like 'Ears'
The locks pivot. The top of the lock is eased to the outside.
The method used, is to pivot both locks out at the same time.
This raises the ram stick up out of the ram slot.
Use your thumbs for the locks, and balance the ram stick with your forefingers. Keeps it from flopping over.
You are using DDR Sdram at 400MHz. (400 MegaHertz)
Also known as PC3200.
You will note that there is a Notch in the bottom of the ram stick.
This cutout lines up with a Locating Lug in the bottom of the ram slot. The ram stick only goes in, in one direction.
The Notch may look like it is centered, but it is not.
There are 184 contact pins on the bottom of a DDR Sdram ram memory module. (Stick)
92 on each side.
The Notch is in-between contact pins 40 and 41.
The Notch is not in the center, but off towards one side.
When you raised the ram stick up with the locks, you will note that each lock has a small slot in it.
The bottom corners of the ram stick rest in these slots.
Notch lined up, bottom corners in the lock slots, gently push straight down on the ram stick.
When the ram stick is fully seated you should hear a couple of satisfying clicks.
This is the 'bump' of the lock, snapping into the notch on each side of the ram stick. When the ram is fully seated, these bumps enter the notch on the side of the ram stick.
Sometimes, the bump does not fully go all the way, into the notch. It will go in real close, though, when the ram stick is fully seated.
IF, you are installing a larger size amount of ram, than you previously have now, and there is also a smaller size of ram stick installed, put the larger ram size stick in Slot 1.
To explain:
Let's say you have a 512MB ram stick in your computer now. You are going to install a 1GB ram stick.
The 1GB stick goes into Slot 1.
(512MB + 512MB = 1024MB, or 1GB)
Slot 1 is closest to the Processor.
The Processor reads Slot 1 before the other ram slots.
(You have 4 ram slots)
Need more information? Hit me up by stating so in a comment.
Posted on Feb 07, 2010
    Guru:
  • 161 Answers
To open your cae make sure you unplug your power cable so that we can lesser the error..
first you need a scew driver...commonly screw driver is needed,
just remove the two scte in the back of your casing..then open it...inside you will surely see your old ram..remove it if you want or try to put the new one with the old one..
try your pc if it will turn on and go to your windows...
sometimes the it will not boot up,because the memories are not compatible with each other...
you'll need to replace the older one with the new one...
hope i've help you.. rate me,,
Posted on Feb 06, 2010
2 Suggested Answers
sp4m771
  • 116 Answers
SOURCE: upgrading RAM on HP digital entertainment center
Most likely, there are some screws on the back of the case. Unscrew them, and pull the casing towards you (when the front is facing away from you).
Posted on Jul 20, 2009
I have a Gateway zx4351. Can I upgrade to a dedicated video card from my GeForce 9200?
It is possible... Yes.
Is it worth it... Maybe the ram upgrade to 8GB is worth the money...
Also, some all in one computers are very hard to even figure out how to open. You better make sure you can do it before you try. You also might want to check if opening the case voids your warranty too.
Specs:
http://support.gateway.com/s/desktop/2010/gateway/zx/zx4351/ZX4351sp2.shtml
Jun 19, 2012 | Gateway 500XL PC Desktop
How do I upgrade my ram on my Gateway All in one zx4250?
I too purchased a Gateway ZX4250 and a 4 GB RAM upgrade kit. It took me awhile to figure out how to open the case. Here is what I found.
1) Remove the two rubber pads at the bottom of the case (don't worry they pop right back on).
2) Open the small back cover.
3) Remove the one screw.
*****CAREFUL****
4) This part is a little difficult but just be careful not to use too much force. Take two small flat head screwdrivers and slowly separate the plastic silver front panel from the plastic black back panel. Start at the bottom where the two rubber pads were removed. Work your way around the case, you can see how the clips are connecting the two panels as you work your way around the all-in-one. It shouldn't be too hard just be careful on how much force you use.
5) Once the panels are separated you can now access the hard drive, optical drive and some other components.
6) Disconnect the Hard drive sata cable from the motherboard.
7) Disconnect the other cable right next to the sata cable on the motherboard (I'm not sure as to the purpose of this cable.
8) Remove the screws from the metal plate covering the motherboard. Take careful note that a grounding cable is connected to one screw.
9) Install your RAM.
10) Reverse the procedure to put everything back together.
This whole procedure to upgrade my RAM took about 15 minutes. I hope this helps some of you that are trying to upgrade your RAM. If you have any questions PM me.
Jan 03, 2012 | Gateway ZX493131e Notebook
Upgrade RAM
DDR 1 - 1 GB costs around Rs 1500 DDR 2 - 1 Gb costs around Rs 1200 DDR 2 - 2 Gb costs around Rs 2200
I just upgraded my system to 2 Gb ddr2.
You can order it on ebay.
Mar 29, 2010 | Lenovo 3000 Y410 Laptop
I want to upgrade my ram on the dimension 4500. how do i open the computer to replace the 256mb with 2 each 512mb chips
unplug your pc from power.
on the back of your case there are two screws on the right. one top and one at the bottom. unscrew these and remove the side of the case.
then you will see the motherboard. to remove the rams there are two plastics on each end of the ram. push them aside and remove the ram.
see here for video
http://www.ehow.com/video_4445703_remove-ram-upgrade-motherboard.html
Jan 21, 2010 | Computers & Internet
I need to put more memory chips in. where do I do it--the monitor or tower? how do I open the cover?
The memory goes in the tower on the motherboard. Most cases come apart by unscrewing screws on one side of the back. Some have a little lever on the back that, when pushed, releases the side of the case that is opposite the motherboard.
Some cases have a button (large or small) that is recessed into the top and maybe the bottom of the case. When pushed these buttons release the catch inside the case and you can swing it open.
Once open, you will see the memory slots. By pressing the catches on each end of the memory chip, you can release them and lift the chip out. Note the position of the key on the chip socket and the slot in the memory chip when reinstalling memory.
Jan 01, 2010 | Compaq FS7600 17" Flat Glass Monitor
How do I open case of aspire R1600 to add more memory
YES the Aspire R1600 can be upgraded to 4GB of DDR2 800mhz easily, and I broke no stickers to enter the unit. Here are the websites. with good internal info and photos for R1600. http://tjdmobile.wordpress.com/2009/11/18/acer-r1600-retired-my-appletv-3-0/ http://netbooked.net/netbook-reviews/review/acer-aspire-revo-review/ Solid-PC needs to research more before they answer. "Guru"... hahaha...
Nov 12, 2009 | Office Equipment & Supplies
Help to upgrade memory of Dell Dimension 8100
Im sure you mean 1GB of ram.
Upgrading ram is possibly the easiest upgrade to a pc.Firstly shut down the computer and remove the wall plug.
Remove the casing
Make sure you touch something metal away from the case before entering the chassis of the computer... anti static wristbands are good.
As soon as you open the case you will see the dimm slots where the ram goes.
You will find two plastic clips on each ram module, just pull these back to release the ram and insert the new ram.You may need to push firmly down to lock them in.The clips will auto lock.
Just be careful not to push to hard as to damage the mainboard.
Nov 11, 2009 | Dell Computers & Internet
Upgrading RAM on HP digital entertainment center
Sep 04, 2008 | HP z552 (PS503AA) PC Desktop
Upgrade ram
If you need them you can find the schematics for the VGN-T27 here : http://www.printcopy.info/shop_e/download.php?brand=Sony&prefix=VGN
Feb 13, 2008 | Sony VAIO VGN-T270P/L PC Notebook
Gateway 7200X PC Desktop Logo
167 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
