Hey mate,
There is two types of sprockets, a spur type and a ring type both are similiar to change.
Spur: remove the side cover & remove the chain and cutter bar then you will see the clutch cover and the sprocket attached, remove the little E clip in the centre and the cover will come out be careful not to loose the little roller bearing, To replace lube the roller bearing DO NOT get oil in the clutch assy otherwise you will have big dramas, and reverse the above steps... be sure to tension the chain correctly if your not sure get somebody that is qualified to check it.
With the ring sprocket it is exactly the same except you do not have to replace the clutch cover the ring just locates on a spline on the clutch cover and reassemble the same as above...
Hope this helps
Brad
