Question about Welding Tools
I have a mig sp-125 and the and the wire feed surges what can i do. is their a place to lube the gears or the drive
    Brigadier General:
  • 4,088 Answers
Suspect that the problem is weak contact with the wire drive mechanism rather than bearings or gears needing lubrication. You may need to disassemble the mechanism looking for weak or broken springs and dirty pivot or sliding surfaces. The wire path in the hand-piece or feed cable may be badly worn. Hope this helps!
Posted on Feb 05, 2010
Lincon mig stops feeding wire
Been welding for a while, open side, check for proper tension on the feed wheel inside side panel, hit the trigger, if feed motor continues to spin tensioner needs tightened or mig wire may be getting hung up inside main cable lead. If motor is off on off on then its probbably the switch on the trigger getting a bad good connection, hope this helps o and check welding tip on gun end, may need replaced if worn or melted, unscrews.
Mar 05, 2012 | Welding Tools
Drive motor for hobart 125
Your Hobart has a Drive Motor Protection.The Drive motor protection circuit protects drive motor from overload. If drive motor becomes inoperative, release gun trigger and wait until protection circuit resets allowing drive motor to feed wire again. Or you can reset it manually by pressing the reset button located on the back welder. If these actions does not work then here's the part number for your motor:HOB 239696.Check our website for pricing you need to call since this is an old welder and pricing needs to be search at Hobart Co.
http://www.praxairdirect.com/webapp/wcs/stores/servlet/TopCategories1_10152_10051_-1
Nov 21, 2011 | Clarke Power Products Clarke 130EN Mig 110...
My welder feeds normal for the first 10 to 20 secs then struggles to feed wire. I have replaced feed tube and wire, adjusted tension both ways andput new tips, currently using .035 for.030 wire. I think it...
Depending on how old you machine is, its possible that the wire feed rollers are worn causing the wire to slip in the grooves. Replacing the WFRs may solve the problem. Test this by watching the feed rollers as you pull the torch trigger, place a gloved hand over the nozzle as the wire comes out and watch to see if the rollers slip on the wire when the wire meets the resistance of the glove. If it does that likely the problem. Hope this solves the problem.
Jun 19, 2011 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Wire feed speed was surging & now the motor just clicks & turns about 1 degree on the rollers. I suspect it may be the relay for the drive motors. Any help with this problem is...
To test your theory you'd need to check the voltage going to wirefeed motor with a multimeter set to DC voltage. This is dangerous as you'd need to have the covers off the machine. If the motor was getting voltage the whole time you pressed the trigger the fault would lie in your wire feed motor gear box. If it is a small mig welder, i would think from the sounds of your fault that it is the gear box that you're having trouble with. To find a replacement you'd need to write down the model number of the mig welder and order a replacement part through a repair shop.
Jun 07, 2011 | Pro Line Welding Tools
I have a ProMig 175. Suddenly the wire feed motor does not work. The solenoid clicks. I have manually turned the wheel trying to reposition the contacts in the motor. No help.
Verify the polarity is correct for Flux or Mig configuration (should be on label under lid) - and ensure there are no loose connections on that polarity wire.
Loosen the tensioner + make sure the wire feed motor turns freely by hand.
My WeldPak 100 and SP-135T were tough to turn, but it did turn freely.
If it does spin freely, then inspect the contacts for the voltage selector. Make sure to unplug the power cord and keep clear of the big capacitor. My SP-135T contacts corroded while in storage.
Apr 12, 2011 | Lincoln Electric LINK2400-+2 CV-305 MIG...
I have a lincoln sp-175plus, when trying to weld it the arc just melts the wire and it balls up at the end. I also put a new contact tip in. As well sometimes the wire feed just stops. I then press...
Your drive tension is too light. There are rollers that the wire feeds through and they need to be tightened. They should push the wire through the gun but slip if you put the tip against a solid object and pull the trigger. If they do not slip, they will jam your gun. Give the tensioner another turn.
Jan 08, 2011 | Lincoln Electric LE 83180 Century...
My wire dont feed out some time when i pull the triger
Inside your machine just in front of the wire spool is an adjustment to increase the tension on the wire tighten it a little bit at a time until your wire feeds
Feb 05, 2010 | Hobart Handler 125 115 Volt 30 To 125 Amp...
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
