Question about Hyundai ImageQuest Q15 15.1" Flat Panel LCD Monitor
Hyundai ImageQuest Q15. Brightness adjustment rectangle stays
I have a Hyundai ImageQuest Q15. This morning when I turned it on a small blue rectangle for adjusting the brightness came up in the centre with brightness and an adjuster level. I tried to remove it by using the buttons on the monitor for auto select and then waiting for the brightness tab to come up and then enter but it does not get rid of it. It will disappear after a while but keeps recurring.
2 Suggested Answers
  • 3 Answers
SOURCE: Hyundai ImageQuest Q15 - screen
it has a problem on button or other wirings not connected on the main...
Posted on Mar 05, 2011
Brighten lcd screen
OK, you are part right. The Fn key on most laptops is written in BLUE. This corresponds to the BLUE legends on various keys on the keyboard. MOST laptops have a pair of generic symbols for the screen brightness up and down . The brightness UP is a blue square (rectangle) with a large asterisk inside. The brightness DOWN is the same except it has a small asterisk inside. You will usually find these two keys as a secondary function of a function key.
Example: On my ACER netbook Fn+F6 = brightness UP and Fn+F5 = brightness DOWN
Nov 13, 2013 | Acer TravelMate Computers & Internet
Adjust screen brightness
Yopu can adjust the brightness of the monitor from the avaialbe panel buttons Alternatively you can do so from the Operating Sytem brightness control which depends on the platform you are using. If its windows you can navigate to control panel and the power settings and adjust the brightness by sliding the slide bar as desired.
Sep 21, 2013 | Hyundai ImageQuest Q17 17" LCD Monitor
Screen shows correct image then goes black. if monitor switched off then on proper screen shows for a second then black again.
problem related to lcd lamp supply
just replace the power supply(called inverter board) connected to the lcd panel lamp
Jan 21, 2011 | Hyundai ImageQuest Q15 15.1" Flat Panel...
Where can I get the cables for the q15 monitor? Can I get them?
Aug 22, 2009 | Hyundai ImageQuest Q15 15.1" Flat Panel...
Need a manual
I have downloaded the manual from Hyundai website
Jun 19, 2009 | Hyundai ImageQuest L70N 17" LCD Monitor
Blue tint
Check the pins on the end of your vga cable from the monitor to make sure that the pins aren't bent.
If they are not bent then it could be a problem with the monitor itself. Try resetting the defaults on the monitor itself and see if the problem goes away if it does then your set.
If the problem still exists then try a different known good working monitor on the computer. If you still get the same problem then its a problem with the video card. If the problem goes away then you know its a problem with the monitor and would need to be replaced.
Jun 02, 2009 | Hyundai ImageQuest L90D 19" LCD Monitor
19inch hyundai imagequest monitor problem, no screen picture
The first thing to check is the power supply to the monitor. Mine went a while ago, black screen nothing happening, turns out it was just the power supply. A quick search on your favourite browser will probably turn up a supplier, I found one that just makes monitor power supplies, so it must be a common problem!
If you have a meter test the power coming into the monitor, or if you're unsure put it to your ear when its plugged in, you should hear a faint buzz which means its working. Also check for any breaks in the cable and/or if there is a fuse in the plug which might have blown**
**If a fuse has blown, it might point to another problem, but at least it's a starting point
Dec 09, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Monitor shows screen then goes black
It is the Monitor Cable connected to the CPU cabinet is faulty. Please check out the cable and its pin firmly.
Try to find the fault, may be the cable broken or tear up.
Let me know if further diagnose required.
Have a nice day.
Oct 14, 2008 | Hyundai ImageQuest Q15 15.1" Flat Panel...
Hyunday HTD21P 21" flat television
hold down the on screen display button (small rectangle inside a larger rectangle) for at lease 10 seconds
May 27, 2007 | Hyundai ImageQuest HQL200NR 20 in....
Hyundai ImageQuest Q15 15.1" Flat Panel LCD Monitor Logo
157 people viewed this question
Top Hyundai Computers & Internet Experts
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
