Question about GE WBSE3120B Top Load Washer
I have a GE WBSE3120B1WW washing machine which makes a loud rapping sound during regular cycles. Upon investigation I discovered that the HOSE FLOOD pipe/attachment has come loose inside and is striking the outside metal... Here's my question: what does it attach to? It seems to just hang there but needs to be secured to something. Any ideas? Thanks. RF
  • 619 Answers
It locks into place at the top which should secure it to the tub properly. If it is not securing a little trick that is used is to wrap the tub and pipe 2 times around with electrical tape to aid in securing. Just a simple trick when the factory recommendation doesn't work. Hope this helps. Rick
Posted on Feb 05, 2010
G.E. WBSE3120B1WW Top Loading WASHING MACHINE
Pull the back off and see where this stuff came from, it is my guess the transmission is gone to lunch.
Sep 20, 2016 | Washing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My GE washer leaks from Hose Flood during agitation - how do I fix it?
It should be connected right next to the drain hose.
Jul 04, 2014 | GE Washing Machines
Wjrr4170g1ww when in agitate cycle it makes a loud banging sound
you have to open it up and look at insides - should be obvious.
Jul 31, 2012 | GE WBSR3140DW Top Load Washer
Standing water in base of washing machine
Is it a front load machine? If so, remove the kick plate under the door and there should be a plastic filter that screws in on your right (approx 2"-3" in diameter). You'll need a catch pan that's lower than the bottom edge of the filter cap, as water will flow out of it when removed. I had one that would occasionally eat a sock or other small article of clothing, stopping up the drain filter and causing the tub to hold water. The added weight of the water causes the tub to not turn at the RPMs needed, and sometimes not at all. Let me know if this helps.
Apr 27, 2012 | GE Washing Machines
What is the purpose of the flood hose? we have a ge wjsr2080t2ww washer. when we use the power wash cycle in super capacity mode as a minute after it starts agitating the water comes flooding out from...
the purpose of that tube so it anywater that comes out of it goes through it and directs the water down the back and away from the motor. Now the bigger issue is why is water coming through that tube.What i suspect the reason of that is that the transmission is defective and the break is that internal to the transmission is slipping so the inner tub turns during the wash cycle force water up the side of the tub into that tube.during the agitate cycle the tub is not suppose to move at all and stay locked into place,but instead its moving where the water is forced up by centrifical force too and out the top of the tub cover,if it leaks with only a small water load it will leak worse with a large water load. if this is what is happening and the tub is rotating on agaitate cycle teh fix for that is to replace transmission which in most cases cost as much as replacing the washer would be
Aug 04, 2011 | GE WDSR2080D Top Load Washer
GE WSXH208A makes a lound noise during the spin
check to see if the washer is balanced (cloths are evenly placed in drum) if it sounds like banging noise
Jan 20, 2010 | Washing Machines
Motor or clutch ?
Clicking noises are most often associated with bra wires , sticking in between the drums , have a good look all around the inner tub with a torch if you spot a wire sticking through carefully pull it out with pliers but dont loose it , once it goes all the way through it is neccesery to completely dismantle tub assy to remove it.
Nov 03, 2009 | GE WBSE3120B Top Load Washer
Very loud during the spin cycle
the top bearing has gone bad you are looking at replacing the transmition and tub seal about 200 dollars in parts the labor is a little tough also you got to completly disasemble the machine to do this may be best to get a new machine
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
GE WBSE3120B Top Load Washer Logo
85 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
