Question about Dryers
Wiring diagram for new power cord
I need to swap the power cord for a new one. What wires do I use? Dryer model DLE 0332W
    Scholar:
  • 91 Answers
TRY TO ORDER A REPLACEMENT FROM THE PARTS STORE IT WILL BE EASIER TO USE AN YOU CAN FOLLOW THE COLOR CODED WIRES, PLUS YOU DONT HAVE TO WORRY ABOUT FIRES OR OTHER PROBLEMS TO OCURR
Posted on Feb 06, 2010
I have a Swhirpool Gold Dryer Model #GEQ885EQ0 and need to know where to look for the wire diagram for hookup. I don't have a book and it isn't shown on the dryer. My stupid son took the wires off and we...
If you are referring to how to properly connect the power cord to your dryer, the following link explains how:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Please note there are TWO different types of appliance power cords. There is a three-prong configuration and a 4-prong configuration. These appliance power cords can be purchased at any hardware store. Just make sure that whatever power cord you purchase matches the receptacle you have in your home.
If you need a wiring diagram of the dryer, the manufacturer usually includes one inside the operator console. Just remove the back panel of the operator console and one should be there.
If you have any questions, please post back and let me know.
NOTE: I believe your model number may be "GEQ8858EQ0". I could not reference anything to the one you provided.
Oct 07, 2010 | Whirlpool Dryers
Moved and the new place has a 4 prong outlet. i need the wiring diagram to switch from 3 prong to 4 prong power cord
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2010 | Dryers
Need wire diagram for 4 wire cord [color code[
Here is a tip that will help you with that problem...
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
May 17, 2010 | Dryers
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
LG elec dryer will not turn on...
Check your breaker. When you swapped one of the hot legs (red and black) with the neutral (white) the breaker should have tripped as soon as you plugged it in. If the breaker isn't tripped, check the wiring diagram to see if there are any internal fuses in the control panel that might have fried.
Aug 29, 2009 | LG DLE2532W Electric Dryer
WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Oct 16, 2008 | Kenmore 64732 Electric Dryer
Dryers Logo
110 people viewed this question
Top Dryers Experts
