Question about Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W
WHEN YOU PLUG IT IN IT RUNS BRIEFLY AND SHUTS OFF
I HAVE HAD THIS FREEZER FOR FOUR OR FIVE YEARS AND HAS WORKED GREAT UP UNTIL NOW. DO THESE FREEZERS HAVE TO BE RE-CHARGED OR MY GUESS WOULD BE THERE IS A RELAY THAT KICKS IT ON AND OFF THAT HAS GONE BAD. ANY ADVICE WOULD BE GOOD.
  • 454 Answers
The easiest thing to try is to completely defrost the freezer by turning it off for at least 24 hours. Often, the coils freeze, and then you cannot get any cold air to freeze your food.
You could also download a manual and electrical schematic from the manufacturer's web site. Use a voltmeter to trace the power and find the problem.
Does the compressor motor still run? Can you hear the fan motor run while the compressor is running? Normally, it is not worth recharging the freon in a freezer. If the freon leaked out (not likely), then you need to repair the leak first. It ends up costing the same as getting a new freezer.
Posted on Feb 06, 2010
Why does it run continually?
possibly needs a service man to recharge the freon
Feb 18, 2016 | Freezers
RF267aewp french door refrigerator is acting crazy. Sometimes compressor fan runs, sometimes it doesn't same with freezer fans. Front control panel will not respond so I cannot get into diagno
Had same problem on my fridge a long time ago. Here is what was wrong on mine. Debris had clogged up around the fan blades to the point where the very small motor that runs the fan was not powerful enough to make the fan turn. When this happens the compressor has to work harder and harder until it finally shut down on safety cutout. I had to open the back of the fridge and clean up the fan blades, [ took the opportunity to put a small amount of oil on the fan shaft too, my Norge fridge is now over 50 years old.]
Nov 05, 2014 | Samsung RF267AEWP - 26 cu. ft. French Door...
I have a kenmore upright freezer model 253.9280415 serial WB10612377 that shuts it self off
You would have to find a local refrigerator repair shop or find a new part from the manufacturer. You may be able to find a service manual online someplace and reset the computer. You could try unpluging the power and waiting five min, plug back in and see if that works.
Jun 06, 2014 | Kenmore Freezers
I have a woods freezer model # V17NAB I defrosted it and after all cleaned ou I plugged it back in. The compressor kicked on but shut back off about 30 Seconds later and will not stay running. It turns...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 22, 2010 | Woods Freezers
We just purchase a used freezer Kenmore Model #
If when you bump it to enable it to run, it indicates a loose connection in the wiring. Most common areas are firstly in the plug. Inspect properly by twisting that area if the freezer is on or off. Either way it will do something. Trace wire carefully up to entry of fridge. Pull and push carefully there and see what happens after that. (Do not electricute yourself .carefully).Cant be to many areas after that.
Jun 04, 2010 | Freezers
Woods Upright Frost Free Freezer
its just the machine defrosting itself, let it wee until its empty, then switch back on and let it settle for 24hours before loading up with beer etc......
May 27, 2010 | Woods 201 cu. ft. Upright Freezer V2003RW3
Freeze on bottom but not on top
when you plug it in do you ear a fan running if not plug the freezer on.and at the bottom of the freezer gently hit were you have a grill sometime the fan motor gonna start running and circulate the cool air if it work keep and eye on it for a few days take care cheers
Jan 15, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore Upright Freezer 253.21741104 Loss of Power
Yes, it does have a control board. It is located under the rear of the freezer near the compressor. There was a service bulletin out a few years ago about the exact problem you are having. I will not be able to find out if your freezer falls under this design change until tomorrow when I get on my computer at the shop.
What is happening is the board has a fault in it that won't allow it to come back on sometimes if the power blinks off and back on. I am not sure if the repair credit is still active but we have changed the control boards on many of these units free of charge as recently as a year ago.
I will reply back when I find out for sure.
Oct 28, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Danby 3.6 cu. ft. / 102 liter Chest Freezer Millenium DCF401W Logo
199 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Michael Van Der...
Michael Van Der...
Are you a Danby Freezer Expert? Answer questions, earn points and help others
