Question about Black & Decker CS1012 7-1/4" 12 Amp Circular Saw
How do i put the blade in - Black & Decker CS1012 7-1/4" 12 Amp Circular Saw
    President:
  • 2,030 Answers
Open the blade gaurd after you unplug it
put a scrwdriver throught the hole in the blade to stop it turning.
use a wrench to take the center bolt lose.
reverse to put the new blade on
Posted on Feb 05, 2010
Why does my riding mower die when put in gear or engage the blades
Check out the grass box safety switch. if not fully depressed it will apply brakes to the blades when in gear. Most mowers are designed with a safety switch to stop the blades, or forward motion if the grass box is not fitted correctly.
Aug 23, 2015 | Garden
How to reassemble blades on wahl stable pro 8800
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
Apr 20, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
How do the blades position
if there timed blade there will be nottches for them to go in if regular blade just put the on put the curled -part of the going toward deck this is up if fin points down that is bottom install blade up blade toward deck bottom this will circulate air through shoot for grass ejection all done
Sep 01, 2014 | Garden
Why is the blade on my black and Decker edger spinning backwards and how do I fix this
if its spining backwards the blade is up side down motors dont run backwards they run clock wise your blade should run clockwise to its possible they put your blade on backwards you will hgave to flip it put it back on
May 18, 2014 | Garden
Jig saw blades wont stay in.
loosen it more before you put the blade in.
Mar 16, 2014 | Skil Saws
Need to know how to get the blade off the miter saw to replace the blade
First, make sure it's unplugged.
On many saws the guard mechanism partially covers the bolt that holds the blade in place. Loosen and move the part out of the way as recommended by the manufacturer. On this saw you loosen a screw and then slide the mechanism up and towards the rear.
Press the spindle lock to lock the blade in place. Turn the bolt clockwise - opposite the normal direction - to loosen and remove it. Remove the outer blade washer and the blade. Leave the inner blade washer in place. Wipe a drop of oil on the surfaces of the blade washers that touch the blade.
Put the blade on the saw so that the teeth point down. Putting the blade on with the teeth facing in the other direction can result in serious injury. Put the outer blade washer in place. Turn the bolt counterclockwise until it is snug, plus another 1/8 to 1/4 turn. Replace the cover and you're finished.
Oct 27, 2011 | Saws
Put a new blade on mower and now when i start it mower shakes really bad. blade is on right and is tight. any ideas
> put a new blade
Take the blade back, and get a replacement blade that is "balanced" (same weight on both ends, and same weight-distribution).
Sep 19, 2010 | Computers & Internet
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 | Wahl 8550
Loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Jan 25, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Black & Decker CS1012 7-1/4" 12 Amp Circular Saw Logo
171 people viewed this question
Top Black & Decker Saws Experts
Jason
Mike Carew
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
