Question about Belkin (F5D5231-4) Router
Belkin N Wireless router no longer has hardwire signal
Belkin N Wireless router has no more hardwire signal-wireless only. I have tried all ports and new cables as well as various computers. Running XP with mozilla
    Novelist:
  • 108 Answers
There would be a reset button on the dotted side or at the rear end of the router.
Keep that reset pressed tight with a paper clip or a needle for 3 minutes with power plugged in. When you are pressing it, you may see the lights flashing on the router. After releasing the reset button, after the lights come up, unplug the power cable and plug it back in after 1 minute. After this if you have the CD, try re-configuring it for your internet service.
In this issue, there are two possibilities, either the IP address is 169.254.xx.xx or else it may show as media disconnected due port speed negotiation.
The above mentioned fix is for 169.254.x.x issues, and media disconnected issues occurs rarely.
But this will fix your issue 99%, but for 1%, you can always get in touch with me with more details like model #, number of computers, etc.
Thanks n regards,
Irwin..
Posted on Feb 06, 2010
How do i connect ps3 to the internet using a belkin router
Hardwire your PS3 to router or connect it wirelessly by scanning from PS3....
Now hardwire your computer to any of the wired ports of the belkin router....
Goto start>run>type "cmd" >type "ipconfig" note down the default gateway address.....usually it ll be 192.168.2.1
now open any web browser and type the default gateway address in the address bar and hit enter.
In the belkin router set up page
Click FIREWALL and disable it....apply changes
click system setting and enable upnp....apply changes
click virtual servers and open the ports for PS3...and enable it...
that all...you are done with it...
you can also enable DMZ....it ll also resolves the issue....
Mar 03, 2010 | Belkin (F5D7231-4) Wireless Router
Every time i hook up the wireless router to the dsl router it doesnt find the internet ( its is a embarq 660 series dsl router and i have a belkin N1 wireless router)
the problem you are facing is due to the double nat issue(the embarq modem provides the ip address in the range of belkin router, that is 192.168.2.1)...hardwire the pc to the lan port of router.
login to the router setup page(type 192.168.2.1 in IE)
in router setup page, click on lan settings and change your lan ip to 192.168.5.1....the problem ll get resolved...if still the status is not connected, switch off the router and modem and switch on it after a minute....it ll get fixed
Feb 12, 2010 | Belkin (F5D8231-4) Wireless Router...
Do you need a hardwired computer to use a Belkin F5D7234-4 Wireless-G Router?
No, you need a wireless lan in your computer to pick up the wireless
signal. Its a piece of hardware.
You need to see what expansion slots you have so you can get a wireless card.
Most laptops come with a wireless card and a modem for phone line
and RJ45 port for Ethernet, cable.
Feb 07, 2010 | Belkin F5D7234-4 Router
I just bought a belkin n1 wireless router at a thrift store. everything works but the wireless part. its all hardwired to my desktop, but my laptop won't pick up a signal from it.
I would suggest going into the router itself at 192.168.1.1, and reset to the factory settings, or if you are familiar enough with router configuration, make sure your SSID is being broadcasted. Also, make sure you are currently using the up to date firmware.
Also make sure you are using the correct security settings to connect up to the router once it's discovered under the "Available Wireless Networks".
Dec 20, 2009 | Belkin (F5D8231-4) Wireless Router...
When i connect my belkin 802.11g router I will no longer be able to connect to the internet. I have never had this router connected to this computer and cant remember if it came with a set-up CD. Please...
well all u need to put ur broadband or hardwire cable into wan port of the router and check ur ips if they are on obtain automatically....then try i hope this will work
Oct 24, 2009 | Belkin Wireless G Router F5D7230-4 -...
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin router, apple lap top and del Inspiron are the three I have in the house.How to connect the new computer to the router?
You should be able to hardwire (Ethernet cable) those pc's to the router. If it is wireless and you are not running cables directly from the router to the pc's, you have to have wireless cards installed in each of those computers in order to pick up the 802.11 wireless signal. The wireless software on the pc will find the router as long as the router is in range. If you have setup the router properly you should be fine. You may just need to power out and reboot the modem and router after connecting the pc's in order to assign new IP's to each computer receiving a wireless signal.
If you have any problems please respond with as much information as possible including model numbers and ISP provider.
Jun 06, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Belkin 8233 - no routing between hardwire and wireless...
Try to see if file sharing between computers connected to the Belkin is working. If it does not try to update the firmware of the belkin. If it does not work its switching function si defective.
Feb 07, 2009 | Belkin (F5D8231-4) Wireless Router...
I tried to reset my security password and now it won't work.
Make sure you have the physical connection connected properly.
-Modem should be connected to the Internet/WAN port of the router.
-Your laptop must be connected to port 1 of the router as well.
-Make sure you can go online hardwired to the router.
Then configure the wireless settings of the router by accessing the router setup page http://192.168.2.1, change the wireless settings.
Jan 19, 2009 | NetGear WGR614 Wireless Router
Hardwiring laptop
hello!
the number ports are the actual ports at the back of the router where you will plug the cable to connect your computer directly to the router.
to find the network key for your wireless connection, you need to connect your computer directly to the router and access the setup page of your router. You need to go to the wireless settings and get the wireless network key from there.
Aug 27, 2008 | Belkin (F5D5231-4) Router
Belkin (F5D5231-4) Router Logo
177 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
