Question about Cherokee (REF) AM/FM Stereo with CD Player and Hands-Free Capability
97 grand cherokee laredo wiring cd player install. can get power to it but have to have battery and ignition switch hooked together how to do it the other way? cause it erases my memory on the cd player when car is shut off then turned back on
  • 102 Answers
Hi the ignition wire needs constant power thats how it saves your memory. You will need a test light to find the wire that is constant power. With the key off touch the light tester to the power wires from the radio harness the one that turns the light on with the key off is the ignition wire and is to be connected to the ignition wire from the radio.
Posted on Feb 05, 2010
  • michael whitman Feb 05, 2010
    Hi I wanted to clarify the solution I gave you. Its the yellow wire that goes to constant power and the red ignition wire goes to the ignition wire that gets power when key is turned on. Thank you for using Fixya.com
Car won't turn on after power steering pump installation?
Did you replace all the wires on the positive side? Also the negative cable bolts to where on the frame? Check those
Aug 01, 2014 | Jeep 2002 Grand Cherokee Laredo 4WD
Why 97 jeep grand cherokee wont start no click ?
Bad ignition switch,
Bad neutral safety switch
Bad starter relay.
Bad starter.
If you understand how relays work, you can remove the relay in the car and jump the switch pins together. If the starter motor turns the engine, you problem is the first 3. If not, its the starter itself.
Jul 02, 2014 | 1997 Jeep Grand Cherokee
Hi 1999 grand cherokee laredo ignition wont turn off,
Get a hammer and punch. Tap on punch next to key while turning key. This will free up frozen tumblers in ignition
Apr 17, 2013 | 1999 Jeep Grand Cherokee
I am looking for the diagram for the ignition wiring on a 1996 Jeep Grand Cherokee Laredo
Here's what I found;
Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness
Sep 15, 2011 | 1996 Jeep Grand Cherokee
Installing a dual cd player in a 2006 scion xb but dual cd player wont cut on unless both consistint power an ignition power are both together, making it impossible to hook up for memory.
The yellow wire needs to go to a constant source and the red wire should go to a switched (ignition) source. There should be a wire that is hot even with the key off.
Apr 21, 2011 | Pioneer Car Audio & Video
97 jeep grand cherokee laredo had sudden loss electrical power no lights, instruments, ignition nothing at all checked battery -12.7vdc checked fuses - ok
Well if your battery and fuses check out fine the next thing i would suggest would be to make sure all your battery cables are good and snug, both at the battery side, and the vehicle side.
Dec 13, 2010 | 1997 Jeep Grand Cherokee
I installed a clarion cd player now cd plat doesn't shut off
THe red wire is to be connected to power from the ignition.Meaning this wire should only be hot, when the ignition is on..
Sep 07, 2009 | Clarion DB538RMP CD Player
Wiring an after market Sony CD Player into a 89 Jeep Cherokee Laredo
there might be a amp in the car , so you need to make sure the blue wire off the sony radio is hook up the the remote wire to the stock amp
Sep 21, 2008 | 1989 Jeep Cherokee
Car Audio & Video Logo
412 people viewed this question
Top Cherokee Car Audio & Video Experts
xxxxxx xxx
Are you a Cherokee Car Audio and Video Expert? Answer questions, earn points and help others
