Question about Frigidaire Kitchen Ranges
I have a frigidiare range that the oven does not heat up at all it is about 2 yrs old it has the digital display you can turn on and set temp but nothing happens
  • 254 Answers
I would check your bake element make sure it isnt damaged or broken.... you could check the element also by turing off power removing the 2 screws inside the back wall that hold the element in place and testing the two ends for continuity with a meter,, if it reads anyting is good if notthin its bad......if its gas then check the ignitors...
Posted on Feb 06, 2010
I set oven temp. It seems to heat ok, during the bake cycle it beeps then shuts off, no display for oven function but the time display remains. Replaced the relay/display board but same.
the beeping is probably saying that set temp is reached just probably oven is still heating so dont turn it off look after an hour if it still on and very hot and worry about display changing its probably how the programmer wanted it to be
Aug 08, 2013 | Kitchen Ranges
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
My oven heats up, but then does not maintain the temp.
If it has a pilot then I would say the thermal couple is bad. If it has a glow type ignitor then the ignitor is bad.
Sep 02, 2009 | Whirlpool GS460 Gas Kitchen Range
Oven quit working burners and digital display work fine
Check to see if the coils are properly connected. If so, you may need to replace the thermostat unit, which monitors the actual oven temperature. Hope this helps.
Jul 24, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Tappan gas range TGF364 not heating properly
try changing oven senso located in the oven cavity (upper right or left). its approximately 4-6" long and has a plug-in on the back of the oven
Mar 11, 2009 | Tappan TGF364AS Gas Kitchen Range
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Amana range will heatup then turn it's self off
F3 F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Oven temp. sensor needs to be replaced. You should be able to look at diagrams with the model # for part location @ http://www3.sears.com/ or http://www.appliancepartspros.com/. The sensor looks like a rod about 4-6 inches long and mounted to the back wall inside the oven. Some can be pulled out from insided the oven by taking out the two screws. If no screws then you will have to pull the oven out and remove from the back.
Nov 07, 2007 | Amana ARGS7650 Electric Kitchen Range
Frigidiare electric range time bake and self cleaning
Not sure what brand of oven this is but there should be a tech sheet on the back of the oven or it may tell you in the owners manual what those codes mean. Might be a faulty oven temp. sensor for faulty wiring/connection to that sensor. If f3 means sensor on your unit and the wiring is ok then replace the sensor.
Oct 03, 2007 | Kitchen Ranges
Kitchen Ranges Logo
59 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
