Question about Kenmore Dryers
Have power to dryer . but now nothing works including light when door is oppened
  • 619 Answers
Bad door switch. Replace door switch and should be good to go. Hope this helps.
Posted on Feb 05, 2010
Door switch wiring
Hi Louis, The courtesy light switch is wired as follows. Power goes to the light. The light is then grounded through either the switch on the light or via each of the door switches. The reason for the interior light to remain on is that one of the door switches is worn and grounding all the time. look for a broken switch or one which is rough when operating. Regards John
Aug 19, 2012 | Cars & Trucks
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Kenmaore 80 dryer - doesn't work at all - the door light comes on when I oppen the door and turns off when i hit the door close switch. I
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 30, 2010 | Kenmore Dryers
I have no power dryer interior light works but nothing on panel?
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 03, 2010 | Kenmore Elite HE4 Electric Dryer
Lock is stuck and the door won't close. The lights are flashing
Disconect fuse at breaker pannel. Then with a plastic dowel or blade trip the lock to oppen. Then it will operate normally. What happened is the lockig mechanisim shut down with the door oppen. Vitally
May 13, 2009 | Maytag MDB9600A Jetclean II Built-in...
Whirlpool Duet GEW9200LQ0 Dryer
can oyu oppen the door nad physically push in on the door switch( little grey switch atop the door opening). do you hear it clicking on/off??? if not you have a bad door switch.
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
