Question about Cooktops
Do the 2 black wires go with the live brown wire?
The two black wires went to live, brown and blue to neutral and the earth as normal. This was for an induction hob.
Posted on Feb 07, 2010
Help with wiring for a drop in stove top
This is not to code. The white is neutral and is of the same polarity as a bare wire. The red and the black are considered hot and would be 220.
Apr 07, 2017 | GE Cooktops
Fagor cook top connection
Guy from Fagor said brown & blue go to black & red. White and ground together go to green & yellow. Hope he's right.
Apr 04, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
Whirlpool Electric Cooktop Wiring
sound like you have a three wire setup on you house most commonly the black wire is the L1 wire or one of the hot wires and the red is the L2 wire and is also one of the hot wire in this instance your white wire would be your neutral/ground wire this would connect to the copper wire on your cook top depending on the model it would have a red wire a black wire and the copper wire but some may also have a white wire also if this is the case on a three wire setup you would attach the copper and white wires together also if needed you can goto the maufactures website and download an instalation guide.
Mar 25, 2009 | Whirlpool GJC3034 Electric Cooktop
Jenn Air Cooktop wiring issue.
Thank you for your enqiry!!
Mar 21, 2009 | Cooktops
Connecting new fan/motor assy
a capacitor is typically inline with your power source and stores a large amount of power to supply bursts of power when heavy draws occur. it sits between the source and the motor so you should have the (source - capcitor - motor) hot wires all conecting at the same place. The other wire on the capacitor should be the ground (if they have +/- markings use the negative as the ground).
Nov 14, 2008 | Amana 30 in. ACC3660AS Gas Cooktop
Left hand side not working
OK. I know whats wrong. On your terminal I guess you only connected the Large Brown wire to the number 2 terminal ( Live ) What you have to do is bridge terminal 1 and 2 together. You may need to peel back the heavy copper brown so you can split it evenly and ensure it can reach to terminal 1 and 2 . So what you have then is one cable feeding to both 1 and 2 terminal. If you have the smaller live brown wire just connect that to terminal 2 also. That should fix your problem. I will check back to see if you have any more problems..
Sep 16, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Chef cooktop wiring
make sure that the white wires are indeed line and not neutral and you probably have the right idea but without a wiring diagram or seeing the unit I cannot confirm this just make sure you aren't hooking up line voltage to the neutral on the unit. also your service has only three wires correct? this means you are piggy backing the neutral and chassis ground (green wire on appliance) not cool on a trailer or manufactured home be careful bud
Apr 19, 2008 | Cooktops
Wiring a cooker top
Thios induction hob (Electrolux) has 4 wires - Y/G, brown. blue and black.
The Y/G is obviously the Earth conductor, and I would assume normality says that
Brown is the live conductor and Blue the neutral conductor.
The quandry is whether or not to disconnect the black wire completely, as this appears to have no function in a domestic wiring circuit.
Regards, Albert.
Oct 27, 2007 | GE 30 in. JP326 Electric Cooktop
Cooktops Logo
177 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
