Question about Whirlpool GHW9400SU Front Load Stacked Washer / Dryer
What is the capacity of washer model GHW9400PW0
  • 254 Answers
Whirlpool GHW9400PW Washer / 27" Duet Front-Load Washer w/ 3.8 Cu. Ft. Capacity, 13 Cycles & 1200 RPM
Posted on Feb 06, 2010
  • Earl-Sr Feb 09, 2010
    that help out at all, any rating?
Trying to figure out the washer capacity for model # 22622 100 from around 2002 or so
suggest you check with the manufacturer's website . model numbers do nothing for us
Aug 30, 2017 | Washing Machines
Capacity frigidaire fwt445ges2 load
Good Afternoon Friend,
I understand you want to know the capacity of your Frigidaire washer, model# FWT445GES2. After researching your model, I found that the capacity of your washer is 4.5 cubic feet. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire GLTF2940ES Front Load Washer
Plastic shaving in wash from ring around basket. What could it be. Model GHW9400PW0 Whirlpool Duet
k where they came off from so you can put them back otherwise it will leak. Inspect the inside of the unit while the tub is out (bearings, etc) to make sure there isnt anything else. Hope this helps!
Jan 30, 2013 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer wont turn on. code is F dL. any thoughts?
"dl" indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Jul 07, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Duet model ghw9400pw0 - hot water supply keeps dripping into drum area when cycle ends.
This sounds like a solenoid valve is malfunctioning -- may just need removing and cleaning or tightening -- solenoid valves are connected to the end of the water supply hose on back of machine.
Charlie
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 30, 2009 | Whirlpool GEW9250 Electric Dryer
What is the drum capacity size on the orig maytag neptune washer?
Drum size or capacity for the Neptune Model Number MAH4000AWW is 3.4
Jan 03, 2009 | Maytag Neptune Washer
What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
May 10, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Whirlpool GHW9400SU Front Load Stacked Washer / Dryer Logo
2,496 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
