Question about Refrigerators
After thawing refrigerator freezer an odor lingers how to stop it. Of course we cleaned it from head to toe. please help
  • 4,793 Answers
Bi carb of soda works like granny said it would......
Posted on Feb 06, 2010
How do I get rid of awful odor coming from bottom of fridge when compressor running
the coils on the bottom are dirty blow out with air and vacuum. you will have to pull out Ice box and clean from back.
Aug 18, 2014 | Frigidaire : FFHT1715LW Top Freezer 16.5...
Why is my frt18s6awx not getting cold enough in freezer & fridge?
Good Afternoon Friend,
I understand that your Frigidaire freezer, model# FRT18S6AWX, is not getting cold enough in either the freezer or refrigerator. I suggest changing the settings to a colder setting and give it 24 hours to stabilize at the set temperatures. Also, I recommend cleaning the toe grille and condenser coils. You can do this by taking the toe grille off and cleaning it with soap and water and rinsing it thoroughly with water. While the toe grille is off, get your vacuum with extension, and vacuum underneath your refrigerator. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 26, 2014 | Frigidaire FRT18S6AW Top Freezer...
Sears Kenmore refrigerator odor in freezer?
A quick phone call to Sears or a local appliance service center may be in order. Since the evaporator that cools everything is located inside or very near the back of the freezer and the freezer has the lowest air circulation of the entire refrigerator, I would suspect a small refrigerant leak. Many refrigerants have strong odorizing chemicals added for just this purpose. Natural gas for heating has these same chemicals to warn us of the danger if a leak occurs. If it is a leak it's not dangerous, but very soon you will come home to a warm fridge and thawed food. Prior to that you'll hear the fridge running constantly as it tries to maintain the proper temp.
Mar 09, 2013 | Refrigerators
How do I test the individual switches on my kenmore, model 106.9738310 icemaker
If you pull off the toe plate at the bottom, most of the time you will have you tech sheets attach to it. I think there is one for the ice maker. Sounds like a possible water valve bad
Aug 19, 2012 | Refrigerators
Bad smell that won't go away
try a bowl of white vinegar for a week or so. m just dont spill it!!
Sep 21, 2017 | Amana 22.6 cu. ft. Side-By-Side...
My express thaw won't turn off
You have a bad main control board problem . Stuff a shelf in the refrigerator section with crumpled up newspaper and leave running ( the ink in the paper absorbes odor . Takes several days to eliminate .
Jul 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Foul dead animal smell from kenmoore side by side refrigerator/ice maker
I'm sorry that I don't have a solution, but we have the exact same problem with an older model KitchenAid side-by-side. Did you get this problem solved? If so, can you share what you did?
May 27, 2009 | Kenmore 50522 / 50524 Side by Side...
Fridge odor
There are a couple of methods to help remove odors from a fridge. The first is a cookie sheet with baking soda spread across it left in the fridge for several days. The other is something called Activated Carbon. Most stores sell it as a carbon odor filter and it is pretty cheap. It actually works better then the baking soda so I recommend you pick some up and just leave it inside the fridge. You can also put this behind your fridge or wherever you have foul odors. Hope this helps.
Nov 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
DRIP PAN
Can you provide me with the make and model of your fridge plz so we can start to fix this problem for you.
Thank you.
Wouter.
Sep 07, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Smelly Fridge
Try putting an open can or two of coffee inside. My mother's freezer had gotten unpluged and it was full of fish. She put cans of coffee inside and shut the door a couple of days later she took them out and the freezer did not stink anymore. Hope it works for you.
May 05, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
