Question about HP Hewlett Packard Pavilion Slimline S3100N PC Desktop
How do I get the DVD out of my s3100n slimline pavilion HP in order to install add'l ram
  • HP Master
  • 5,381 Answers
The manual with pictures is available here: http://h10032.www1.hp.com/ctg/Manual/c00877796.pdf . Page 9 has the optical disc removal steps. The steps are remove the cover then remove the front cover (press two tabs apart at the bottom of the cover and the two tabs on the top together. push that out). If your computer has a Pocket Media drivem lift the tab on that cage and pull it back and out of the chassis. Disconnect the power and data cables from the back of the drive, noting their orientation. The power cable gets gently rocked back and forth; pull the tab on the data cable. Disconnect an audio cable if needed. Remove the screw from the side of the optical drive and pull the latch away. Push the drive forward and out without tilting it.
Now you should be able to locate the memory sockets.
I hope this helps.
Posted on Feb 05, 2010
  • 30 Answers
Most slimeline cases have DVD that remove from the front. That is you will have to remove the front plate of the computer to slide the DVD out. Close to the inside corners on the front usually are compression fit plugs that snap into place, ocassionaly screws but not often. Take your time and slowly push them outwards once you have all of them loose on one side you can gently rock the front back and forth until the other side dislodges.
It is important to not use excessive force or you could break the pins in which case you will need to have some glue handy.
Hp desktop alarming when turned on
Open the lid. Blow (or vacuum) dust away from CPU heat sink.
Take out RAM clean the edges with thick cloth. Put back and try again.
Jun 17, 2014 | HP Hewlett Packard Pavilion Slimline...
How do i reset my HP provillion slimline s3100n pc back to factory setting without a recovery cd
you cannot recover or reset with out a recovery CD
or
just format it and install a fresh copy of operating System
Aug 29, 2010 | HP Hewlett Packard Pavilion Slimline...
Hp pavilion slimline s3100n doesn't display on the monitor. boots fine and fans spin and stuff, it just doesn't recognize its own VGA output. What do i do?
Hi
First,try hooking it up to an external monitor if you have access to one.Unfortunately,we need video to start checking for what may be wrong.
Try the monitor and post back to let me know what happens,and if it shows on the external display we can start looking at potential problems and fixes.
Bob
Aug 21, 2010 | HP Hewlett Packard Pavilion Slimline...
Looking for any complaints regarding the motherboard for the HP Slimline s3100n.
HERE is a whole site of listed complaints regarding the computer you listed. HP Slimline s3100n. I hope this helps and is what you were looking for.
Jun 22, 2010 | HP Hewlett Packard Pavilion Slimline...
Slimline s3100n keeps shuttubg down
scan for viruses. maybe it is infected. if still, do the recovery options for hp.
Mar 08, 2010 | HP Hewlett Packard Pavilion Slimline...
How do i remove the dvd from an hp s3100n desktop.
You need to take the cover off the computer on both sides. Normally the optical drive is secured by four screws, two on the left and two on the right. Take those screws out and slide the drive forward enough to get to your memory stick. You may not have to unplug the cables, but if you can't slide it out far enough you will.
Jun 27, 2009 | HP Hewlett Packard Pavilion Slimline...
How do i remove the dvd from hp s3100n
Hey there, sounds like it is stuck in your drive? Simple, there is a small hole in the front of the drive, put a paperclip in there to push the drawer out
RAM replace on Hp pavilion slimline s3100n PC
Ok, what you've got to do are the following.
1. Remove outer cover. (you've obviously already done this)
2. Remove holder for personal storage device.
Pull up brown/black lever untill the unit lifts up and out
3. You can now see black screw holding in DVD/RW Drive - remove it.
4.Lift latch that you described
5. Push DVD Drive forward until you can access the memory
Jun 24, 2009 | HP Hewlett Packard Pavilion Slimline...
HP Pavilion Slimline S3100n keeps shutting down to powersave
It may be a virus or trogan problem. DO clear the Internet explorer cache and browsing history. remove all unwanted programs using add remove programs. please reply to me if u can solve with thos solutions
Apr 06, 2009 | HP Hewlett Packard Pavilion Slimline...
I need to reset the ram on a hp pavillion slimline
The DVD drive should have one or two small phillips head screws on the side that will allow you to slide the drive out through the front of the PC. Just be careful that you don't damage the ribbon cable when you do this.
Mar 19, 2009 | HP Hewlett Packard Pavilion Slimline...
HP Hewlett Packard Pavilion Slimline S3100N PC Desktop Logo
176 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
