Question about HP PSC 1610 All-In-One InkJet Printer
"out of paper"
When I try to print, it will feed the paper half way and then say "Out of paper" but it is not at all out of paper!
    President:
  • HP Master
  • 2,022 Answers
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Have a nice day and do not forget to rate please...!
Posted on Feb 06, 2010
The printer only prints half a page then moves to next page and a
Before printing, the printer checks the paper size. If the paper edge guide is positioned incorrectly, the paper may be fed at an angle. If this happens, the bottom of the paper is therefore at an angle and not perpendicular with the paper feed rollers. This can result in the paper sensor not recognising the real page width as it can only detect a certain amount of the bottom of the paper sheet which is nearest to it.
If only part of the width of the paper is detected, the printer considers that the paper width is less than it actually is. To avoid printing on internal parts of the printer such as paper feed rollers, the printer automatically cuts the image to fit the detected paper width As this phenomenon depends on the paper feeding condition, it can be random.
Reload the paper and make sure it is loaded correctly. All the way to the right and the paper guide correctly adjusted.
Feb 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Dell photo aio Printer says Error:2200 Will only feed paper half
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
Aug 26, 2009 | Dell 926 All-In-One InkJet Printer
When printing back side of paper, paper turns sideways and tears in half.
see that u r feeding the oaper straight. Try to feed the paper manually instead from automatic feed. Also remove the curl of the paper form the top end by hand before feeding
Aug 11, 2009 | Canon imageCLASS D680 Laser Printer
HP Officejet Pro L7580: says load paper/won't print
Go to printer and faxes and cheeck the preferences of your printer cheeck the number of copies and all strange that you will saw.
i hope my advice is helpful.
May 19, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Paper doesn't feed
It could be a few things, but the times I've had similar problems it was either caused by the feed/gripper rollers in the paper trays being worn out, thus not feeding any paper or feeding half a sheet and then jamming.
Or, it could be that the elevator in your paper tray isn't lifting, but if it's taking paper it's probably the rollers.
Jan 12, 2009 | Canon Office Equipment & Supplies
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC1510 Feeds paper half out then stops
Clean the roller that feeds the paper (located at the right side inside the feeding tray).
I did it ,with a cotton pad: first impregnated with water an soap, then only with water to clean the soap and then with a dry pad. I did making the roll to roll printing a page without paper in the try and continuosly presing the cancel/resume button.
Mar 11, 2008 | HP PSC 1510 All-In-One InkJet Printer
Check paper light blinking and "E" code
trying to print the las job you had.
Try hiiting the cancel button when you turn it on
Oct 22, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
