Question about Creative Labs Sound Blaster Live! 5.1 Sound Card
How to hook up audio output and line in
How to hook up audio output and line in.
picture of back of board and lables would be nice.
Sound Blaster Audigy 2 Pn # J1148 Rev.# A00 Win 2K/XP
Driver 5.1201.328 Build SBA2-SLS1D-W3-LB
    Genius:
  • 1,027 Answers
The sound cards have unified color codes; green jack is sound out, and the blue jack is line in.Mic in is pink.
Posted on Feb 06, 2010
Tip
SONY GRAND WEGA ERROR CODES AND WHAT THAY ARE
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
on Apr 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sound card isn't working and I have installed drivers now with speakers hooked up it tells me they are unplugged
Test sound via headphones to isolate problem. The green input is for speakers. Some cards will also allow you to change input / output, but this is dependent on their software.
Aug 20, 2012 | Compaq Creative Sound Blaster PCI 64 Sound...
No audio output
the audio output appears to be directly next to your ethernet port the three consecutive headphone jacks green is line out pink is line in if your not receiving any audio after having speakers hooked up I would say look at your computer bios and make sure your on board sound is enable than check to make sure your drivers for the board are all up to date
Mar 30, 2010 | EliteGroup P4M800PRO-M Motherboard
Is there a free download fro an audio output
If you are refering to the Sound Blaster Live card you can download the software here:
http://support.creative.com/Products/ProductDetails.aspx?catID=1&subCatID=206&prodID=4857&prodName=Sound Blaster Live!&subCatName=Live!&CatName=Sound+Blaster
Be sure to pick the correct operating system.
Oct 24, 2009 | Creative Labs Sound Blaster Live! 5.1...
NOT GETTING PROPER SOUND
Dear Sir,
Welcome to Fixya,
Creative Sound blaster cards are plug and play cards, they generally installed on PCI or Expansion slots of your motherboard,so there is no question of cables.First check your speaker and audio properties of your PC.If it is correct check your speaker audio pin make sure that pin is firmly inserted on your sound carder line out.If it is also correct,remove side cover of your pc cabinet,then take out the sound card and reinstall on another PCI slot of motherboard.I think it solves your problem.if it is not may be problem with your Creative sound Blaster audio card. I think it helps.If you have any problem post a feedback we were glad to assist you
Have a Nice Day!
Sep 30, 2009 | Creative Labs Sound Blaster Live! 5.1...
I recently updated my Creative Sound Blaster Xtreme Audio Card and RealTek HDMI Audio Output drivers, and now it seems they won't work with each other. I cannot get sound on my computer.
sound blaster cards are known problem makers they don't play well with others go to start-controll panel-system-hardware-device manager and find your realtek hdmi and disable it its eather 1 or the other you cant have both. sorry
Jun 29, 2009 | Creative Labs Sound Blaster X-Fi Xtreme...
Hi again
yes 3x its lamp cover no doubt. ballast supply will give different error on this unit. this should help hdtv man
Diagnostic Item
Description
Number of times
STANDBY or LAMP LED
lamp flashes
Probable Cause Detected Symptoms
Fan error 4 times
Temp error 4 times
Audio error 7 times
- Blowout of a fuse
- IC failure
D-OVP error 8 times
(A board, B board)
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
I purchased a sound blaster X-Fi extreme audio notebook card, installed iti into my XPS M1730 Dell laptop computer amd I can not get any sound, AT ALL. Please help me to be able to get a 5.1 surround sound...
Hello!
im affraid to answer your question because in most cases you will rate me " thanks for trying" it hurt me but it's ok because i want to help you.
First install the driver of your "sound blaster X-Fi extreme audio notebook card" the Utility cd is enclosed in it. after that Hook your speaker to the output of the newly installed card. and then go to control panel , double click the "sounds and audio devices" and then in the "audio tab" and in sound playbak. select the device according to your sound card.
You can adjust some setting there and click ok.
may this solve your problem.
best regards,melnavz
Mar 07, 2008 | Audio Players & Recorders
Hi need sound
Certain early models of the Sound Blaster cannot do both MIDI input and wave (audio) output at the same time. Thus, if you've selected "Creative Labs" as a MIDI In device in Cakewalk’s Options | MIDI Devices dialog, wave audio output won't work. Note that MIDI output will work fine along with wave audio output: you can select Creative Labs from the list of MIDI Out devices. The problem occurs only when you've selected the Creative Labs MIDI In device.
Hope that helps!
Dec 08, 2007 | Cakewalk Guitar Tracks Pro 2 Classic
Creative Labs Sound Blaster Live! 5.1 Sound Card Logo
141 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
