Question about Panasonic Viera TC-L32X1 32 in. LCD HDTV
How do I setup my full hd freesat tv I have sky + do I take the dish cable out of the sky box or do I need another cable from the dish
  • Panasonic Master
  • 12,061 Answers
If you really want to do this, well then you could use and antenna switcher, a small control box that the Antenna from the dish plugs into it and the Sky Box & Freeview each, plug separately into that box too, and then, you can select, which one the antenna is connected to. (Some even have remotes) OR you could simply "Split" the signal "IN" with an Antenna "Splitter" and run one feed to Sky & the other to Freeview. Now thats all amusing that you can get freeview from that Dish.
Posted on Feb 06, 2010
Sky+hd box isn't getting a satellite signal
have you checked the cables to the lmb ( dish ).... or take the dish cables out of the back of the sky box. wet your finger and put finger on to the centre and out part of the cable connector that some times works. faling that the sky box may need a factory rest or is damaged or the lmb has gone.
Sep 05, 2013 | Televison & Video
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
Can i set up my blu ray recorder DMR-BS750 without
The purpose of that freesat to bo able to record/playbak 2 channels at the same time. But you still need a satellite dish pointing to the satellite in the sky so it can work.
Jan 13, 2010 | Panasonic Televison & Video
Just bought a Panasonic TX-P42G10B 42in 600Hz Full HD with freesat HD built in. We currently have Sky +, but i was unwilling to pay the extra a month for the sky HD service. Therefore this tv seemed fine....
Use a good quality scart leads for starters.
connect oon end to tv and the other labeled tv on sky box. The other is labeled vcr. connect another lead from vcr or dvd to that connection.
If you have a hd dvd player or Bluray, then buy a HDMI lead and connect straight to one of the HDMI inputs on the tv. I know this is late but i hope it still helps you and anybody else who may read this.
Dec 28, 2009 | Panasonic Televison & Video
Unable to hook up my ''Dish'' cable to the TV
If the cable comes from the dish,then unless you have a freesat tv that will not connect into your tv.The cable from a dish normaly connects into a sky box or cable box.You need a cable from an aerial to connect into the tv.
Nov 11, 2009 | Sampo PME-42V3 42 in. Plasma Television
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
Ive just moved to a house with sky all ready and have not got a clue how to set the thing up. I have a 50in PS-50Q96HD Samsung HDTV Plasma. I have the sky cable and the normal tv cable, what goes were...
first of all you would need to have a Sky HD set top box.
The cables coming into the wall.. you said one was the terrestrial aerial and the other was a sky cable. In order for you to benefit from Sky HD you would need twin cable or two single cable running from your sky dish.(allows you to record a program and watch another etc.
summary:
skyHD box
two feeds coming from your dish,
there is only one place these can go as they are screw on ie F connectors. so they would screw onto input 1 and 2 on the back of the Hd box.
Run a HDMI cable from the back of the sky box from the HDMI port to one of the HDMI ports on the back of your telly. last but not least you would need to get a power cable (kettle plug) to power the thing.
In regards to your terrestrial aerial you can plug this directly into your telly or via your aerial in port on the back of the skyHD box. then you would have to run an aerial cable from the RF out 1 or 2 to the back of your telly this would allow you to record two things on your Sky HD box then switch to your built in freeview that your telly has.
Hope this has answered your questions
Cheers
Little Dish Fitter
Feb 28, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Unable to get sky on panasonic tv
You cannot drive both from a single cable. You require a dual LNB fitted to your dish (replacing the single LNB). This has two cables out , one to sky and the other to the TV. If you have your own dish this should not be a problem.
Jan 09, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Panasonic Viera TC-L32X1 32 in. LCD HDTV Logo
374 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
