Question about Hunter 34357 Humidifier
Hunter 34357 displays LO instead of number in humidistat
In the humidistat display, the letters LO appear instead of the existing humidity. Nothing in the instructions about this. The LO wont go away
  • mafeb
    mafeb Jan 22, 2012
    Anyone else found a solution on this?
I have the same problem. And nothing in the instructions. Searching for a solution now.
Posted on Nov 12, 2011
Recently purchased clock with tempature and humidity dials, humidistat not working It is outdoors in southwest Florida and it says the humidity is 50 %,no warranty or instructions
what makes you think that the humidity is not correct
it is a indicator that will not move much so don't expect it to move around like a temp gauge or barometer
May 15, 2017 | Humidifiers
After refilling tank of my 34357 Hunter Humidifier, I set humidity level so it exceeds the actual humidity in the room, but the unit will not run when I turn it on. The green lite is on. I tried unplu
do you hear the motor humming like it's trying to run? If so it's most likely because the water impeller at the bottom of the assembly attached to the motor is frozen because of mineral deposits. If this is the case, soak the assembly in vinegar for about three days to loosen it up. If the motor isn't turning/ humming I would imagine the humidistat is faulty. Good luck, they don't have replacement parts other than those listed in the manual or online
Jan 27, 2015 | Hunter 34357 Humidifier
HM512W1005 HONEYWELL TRUESTEAM light flashes 6 times. What does that mean? Also, where can I get a list of codes? Thanks
I recently contacted Hunter and they said the loud motor in the Hunter 34357 humidifier can NOT be replaced. Instead, they can provid a pro-rated refund, depending on how long you have owned your humidifier. A receipt from your purchase is needed to get a refund. Contact Hunter at http://www.hunterfan.com/Support/Contact-Us/
Nov 27, 2013 | Honeywell Truesteam HM512W1005...
Honeywell humidifier short cycles
It's not uncommon for duct work in an older home to Bang as the furnace cycles due to age. The humidifier banging while turning on and of is mostlikely the solenoid valve; if the solenoid is bad it is actually to your benefit to replace the entire humidifier as the solenoids are very expensive, 50%+ of a new humidifier. Plus you get the 5 year parts warranty on the new unit instead of just one year on the solenoid. If you don't want to replace the entire unit you can replace the Humidistat, and that should fix the on/off cycling, however a new humidistat is included with a new unit, which again is more cost effective. They are easy enough to replace as a do it yourselfer, especially when replacing an existing unit. I hope this helps you.
Dec 29, 2012 | Honeywell HE360A1027 Whole House...
What is the differnce between a Humidistat and a Dehumidistat and will they both operate to get rid of humidity with the ducted air conditioning system?
Hello, a humidistat is a control used to adjust the amount of humidity you prefer. A demumidistat is the exact opposite and is used with a dehumidifier
Apr 08, 2012 | Humidifiers
Fan makes noise
Not sure how long you have had this humidifier. If the motor is getting louder it probably needs a new motor. It is possible if it is making a fan blade noise that something is hitting the fan blade. If that is happening try to open enough to see if the fan blade (impeller) is being impeded.
Mar 27, 2012 | Humidifiers
Humming sound coming from my 550 humidifier thermostat. the dial to control humidity is not responding and wont turn off
Hello, sounds likemyou have either a bad humidistat or solenoid valve, disconnect the wires from the humidistat if this turns off the humidifier than replace the humidistat. If not the solenid valve will need to be replaced,
Sep 17, 2011 | Aprilaire 550 Humidifier
This is getting old. I may be able to get #1 replaced - am persuing that. As far as technical help or schematics, we are getting nowhere. At this point I do not feel I have received my money's worth...
If Hunter provided a wiring schematic for their dehumidifiers, you would had a response well before now. All they do provide is the Owner's Manual and a list of replaceable parts for your unit.
http://www.hunter-humidifiers.com/manuals/34357.pdf Just in case you have misplaced yours.
Certainly, if you call their Tech Service Dept 1-888-830-1326, they may furnish one to you via email with an attachment, as well as sell you any parts you may need. If your unit is not still under the Five Year Limited Warranty.
Good luck and hope this helps you get the schematic you need.
Jun 21, 2011 | Hunter 34357 Humidifier
Have two Hunter humidifiers - model 34357-about 5 years old #1, fan just quit running. All else seems normal. #2, Unit starts running and then stops with the humidity reading at max. Since the...
This is the manual for your de-humidifier. It lists the part number for the power and fan control switch and it states they have a 5 year warranty.
This is their link for support:
http://www.hunterair.com/suppo.95rt
They have a msrp on the unit at 84.95. What I wuld do is definately check into the warranty ting with them and I'm sure you could probably salvage one ot of the two units. Replacement parts may not be cost effective. You can test the motor from #1 in #2 and, if it runs, you know it has to be a switch or a start capacitor, etc. I guess it all depends on how much tinkering you want to do. I would think there is a good chance there is a wiring diagram for the motor somewhere inside the case or on the motor. Good luck.
Dave
Jun 05, 2011 | Hunter 34357 Humidifier
I have a aprilaire 600A I have hooked it all up but for some reason the number display doesnt show anything. The controls all light up, but no display. Also for some reason no water is coming out.
Thank you for contacting us. Does your humidistat have a blower activation switch on the lower left hand side of the humidistat? If you do it is our #60 humidistat, and if it is not there you have a #58 humidistat. The R & C are the two connections that supply power to the humidistat to give you the numbers on the digital display. The 60 you wire right into the R & C off the furnace panel. The 58 you need a constant 24 volt and 10 VA power source which you could get by using the transformer off a constant 120 volt power source to power the humidstat. If you are doing this correctly and you still do not get the numbers to show up, then you have a bad humidistat and you need to go back to where you purchased it from and exchange it under warranty provided you used a certified HVAC contractor to do the installation. Our warranty is only valid if you used a certified HVAC contractor to do the installation. If you have any additional questions please contact us at 800-334-6011.
Thank you
www.aprilaire.com
Kevin Engen
Customer Service
Research Products Corporation
Nov 09, 2010 | Aprilaire 600 Humidifier
Hunter 34357 Humidifier Logo
211 people viewed this question
Top Hunter Humidifiers Experts
jdthefixer
ka4iup
ka4iup
Vernon Taylor
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
