Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Lcd projection TV not turning on red light blinking next to stand by.
SOURCE: Will not turn on
8 times is the highvoltage splitter prety cheep part .
Posted on Apr 03, 2007
Mine is blinking constantly the light for timer. We unplugged it for a day and still continues blinking.
Posted on Apr 06, 2007
SOURCE: no picture blinking stand by light
I hve worked on a number of these units , your description is typical of a shorted blue picture tube. The protection circuits in the tv detect that there is a problem thus shutting the unit down to prevent further damage. Sony had a bad run of picture tubes in this series. The replacement cost of the tube is about $250 plus labor. My estimate would be for the repair about $400-500 depending on where you live and how honest your local technican is. I will caution you however, that you could replace this tube and the red or green could go. These would not be covered by the technicians warranty. When these sets are working, they have a superb picture and it is easy to get lured into fixing them. Scrivitron
Posted on Jun 16, 2007
skippy101
  • 143 Answers
SOURCE: 1996 sony projection tv model kp46s17
does the tv realy shut off or does the pic go away sounds like bad tube
Posted on Nov 03, 2007
  • 5 Answers
SOURCE: sony projection tv no power
I purchased a service manual for $16.99 from ServiceManual.net. I downloaded the manual. Read it and you have to make note of how many times the power LED blinks red. My 55" Wega was blinking 6 times then pause then repeat.
The manual indicated it was a "Low B error, No "DD 6V" output ( G1 Board) No picture/No Sound.
The manual gave me instuctions on how to remove the G1 Board. I took it out and clean off the dust reseated the G1 Board, still the same problem. I order an new G1 Board, part# A-1060-177-A from the "Partstore.com" for $186.25
Problem is fixed and I save $350 on service call.
Bobby G aka poolmvp1
Posted on Jan 02, 2008
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Hitachi tv LCD blinking red light tv wont' turn on. replaced lamp model 60V500A
I have hitachi lcd rear projection tv model 60v500A at first I was getting a red spot on centar of tv with in two mounths the spot got bigger. I chanched the lamp but now i don't have a picture, the red indicator on tv is now blinking.
Aug 10, 2010 | Hitachi Televison & Video
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
Tube 27" sony tv, stand by timer light blinking red?
It has a faulty power supply or processing boards. Must take to agents to sort out. Nothing you can do on the outside.
May 12, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony grand wega KF60DX100 Won't Power on
THE RED LIGHT THAT BLINKS IS IT THE LAMP BOX THAT THE RED LIGHT BLINKS IN OR THE STAND BY LIGHT THAT BLINKS ? IF ITS THE LAMP BOX THAT BLINKS THEN YOUR LAMP HAS BLOWN AND NEEDS REPLACED YOU CAN FIND THE PART # FOR YOUR T.V. FOR A NEW OR REFURBISHED LIGHT IN YOUR OPERATING MANUAL AND WITH THE PART # BUY A NEW ONE OFF EBAY,ALSO YOUR OWNERS MANUAL WILL GIVE YOU STEP BY STEP INSTRUCTIONS ON HOW TO REPLACE IT AS THIS IS A COMMON PROBLEM WITH PROJECTION T.V.'S IF ITS THE STAND BY LIGHT THAT BLINKS I NEED TO KNOW HOW MANY TIMES IT BLINKS AS THAT'S A SELF DIAGNOSTICS CODE THAT YOUR T.V. IS GIVING FOR THE PROBLEM AND FOR SONY THERESE NO CODE FOR 1 BLINK OF THE STAND BY LIGHT.
Mar 16, 2009 | Sony Grand WEGA KF60DX100 60" Rear...
Picture cycles off and on
I replaced a burned out xl-2000u bulb with an after-market Philips bulb on my Sony KF60XBR800. After a fews weeks, I started experiencing intermittent black-outs with the "stand by" red light appearing. After a couple weeks it became intolerable. I then purchased an OEM Sony lamp and the problem has been gone for months. I read somewhere that the Sony circuitry monitors either resistance or watts and shuts the thing down for board protection. It was said that it is so sensitive it can can use only the Sony bulb. I'm a believer. If the bulb is going bad, i wouldn't doubt the protection circuit can kick in.
,,,,Pat
Nov 21, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Red stand by light blinking
5 blinks = lamp driver (ballast) failure.
1-468-798-14 for the 610 model
replacement is done from the back of the set, should be straight forward, keep the red ballast wires apart for best results
if a tech replaced the red tube, you have an older tv where 5 blinks is the AKB error meaning your CRTs are getting old.
Nov 17, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
When you turn the tv on the red light on the front(stand by/timer)flashes and the tv starts to come on and then it turns off.
Do you mean the screen turns on briefly or the stand by light just keeps blinking. If the tv turns off after switching on then it probably means a protection circuit fault. Also please provide me the number of times it blinks before it pauses. Awaiting your resposnse.
Regards,
Sai.
Aug 19, 2008 | Sony Televison & Video
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
20 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
