Question about Whirlpool Washing Machines
Our washer recently started to leak and we have been unable to find a manual so we can break it down and repair it. It also becomes unbalanced very easily. Do you know where we can get one? Model # LA5530XSN2 Serial # C84204314 Stock # LA55305
  • 254 Answers
To get a parts breakdown of this go to sears.com go to upper far right hand side click on parts and service,, go down to parts under home services ,, type in your model number use the xsw2 one as the w or n just distinguishes what color it is same thing... this will give you a breakdown of the parts as well as part numbers hope this helps...
where
Posted on Feb 06, 2010
  • Earl-Sr Feb 06, 2010
    where is it leaking from if from bottom it could be your water pump, u can check by pulling unit out a lil bit and tipping it back u can see the pump from undernaeth it will have two hoses going to it, turn power off before u replace the pump if that is ur problem...
    the part number for ur water pump is 3363394 u can see a pic of this part at repairclinic.com also...hope this helps
My bravo washer is not starting a cycle when I press start button. Also water is still in tub from last load that did not drain.
Sounds like you washer is trying to spin out and becoming unbalanced and cutting off.. Move timer to spin and see if water spins out. If so try running a load and say with it so if it becomes unbalanced you can arrange clothes before returning timer runs out.
Feb 20, 2016 | Maytag Dryers
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
Unbalanced load
it could be your pump blocked and not discharging the water it will become unbalanced not spin
Nov 22, 2011 | Whirlpool WTW6400SW Top Load Washer
Washer spins than it gets off balance and shuts
Hi, Washing machines can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Take care
Jul 14, 2010 | Whirlpool Washing Machines
Becomes unbalanced very easily recently
There is a small spiral spring between the bowl and the cabinet, which help hold the bowl away from the out of balance switch.....OOB switch is at the back RHS of the machine, the spring is situated diagonally opposite (LHS Front). Lift lid, remoce 2 round plugs and loosen screws. Carefully lift hob and check the spring!.....I hope this helps...good luck...Nomess
May 17, 2010 | Fisher Paykel EcoSmart GWL15
During the spin cycle the drum becomes unbalanced and thumps.
I assume that your saying this happens all the time and not just because you have too many clothes on one side of your washer. First make sure your washing machine is level and there is no problem with the feet. If that checks out take the cabinet off the washer and check the tub hold down springs/straps and make sure they are still attached....they can come loose or break. Hope this helps!
Apr 24, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Neptune Top Load Washer will not spin and water will not drain at the spin portion - the laundry becomes un-balanced. I have checked to ensure the machine is level per manual - once you reposition...
If your machine ius a FAV6800A LED console or FAV9800A LCD console then take a look at this post Clutch Fix if you want to DIY.
I will help you through the process. Your looking at $300 to $400 for a repair if you don't DIY. See if the DIY process is for you if so let me know I have a few additional questions......Rich
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore washer started making banging noise in last spain cycle. Now unable to spinn drum by hand.
Having same problem with my Kenmore 500. Tomorrow will be the second time a repair man has visited the house. Washer on 5 weeks old. Drum bangs every other load. Load not unbalanced. Avoid this washer, it is a POS.
Mar 20, 2010 | Kenmore 24902 Top Load Washer
Tub bangs loudly
there may be 3 to 4 load springs on the underside of the machine that attatches to the tub. if one of these breaks which often do on my machine. They will cause the machine to become unbalanced and bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
Nexxt 100 Series Washer
seperate sizes of clothes towels with towels shirts with shirts. if the washer gets unbalanced and cant balance itself it will shut down after ex amount of trys. your owners manual does discuss this in the trouble shooting section
Nov 08, 2007 | Washing Machines
Washing Machines Logo
Dan Webster
Dan Webster
Sal DeAngelo
