Question about Measuring Tools & Sensors
Accuturn 1200 hood switch;
Left an accuturn 1200 wheel balancer on with the hood up for about an hour, when I returned, it was off and would not power back on, finally got it to turn back on, but now it doesn't recognize when the hood is up or down, and constantly throws the error code e29, which states that the hood is up, even when it is down.
  • 12,061 Answers
Check the sensor/switch that indicates the Hood is Up, ensure that it is OK. Make sure the Switch/Sensor is being "Activated" by the Hood being lifted,
Posted on Feb 05, 2010
I have Toyota 2006 sienna and front right wheel shakes or wobbles ... I have new front tires and balanced.. but still wobbles a little...please any thoughts?
Hi Scott.
Try switching the wheels from left to right side and see if the wobble goes with it.
If not, look for a worn tie rod end or other suspension component.
If wobble goes to left side, look for bent rim.
Cheers.
Oct 10, 2015 | 2006 Toyota Sienna
Tip
Watch glossary: R.
RATCHET WHEEL
Toothed wheel prevented from moving by a click pressed down by a spring.
REGULATING UNIT
Made up by balance and balance spring, governing the division of time within the mechanical movement, assuring its regular running and accuracy. As the balance works like a pendulum, the balance spring's function consists of its elastic return and starting of a new oscillation. This combined action determines the frequency, i.e. the number of vibrations per hour, and affects the rotation speed of the different wheels. In fact the balance, by its oscillations, at every vibration (through the action of the pallets), frees a tooth of the escape wheel (see escapement). From this, motion is transmitted to the fourth wheel, which makes a revolution in one minute, to the third and then the center wheel, the latter making a full rotation in one hour. However, everything is determined by the correct time interval of the oscillations of the balance.
REGULATOR
Regulating the functioning of a movement by lengthening and shortening the active section of the balance spring. It is positioned on the balance-bridge and encompasses the balance spring with its two pins near its fixing point on the bridge itself. By shifting the index, the pins also are moved and, by consequence, the portion of the balance spring capable of bringing the balance back is lengthened or shortened by its elastic force. The shorter it is, the more reactive it tends to be and the more rapidly it brings the balance back and makes the movement run faster. The contrary happens when the active portion of the balance spring is lengthened. Given today's high frequencies of functioning, even slight index shifts entail daily variations of minutes. Recently, even more refined index-regulation systems were adopted (from eccentric to micrometer screws) to limit error margins to very few seconds per day.
REMONTOIR or CONSTANT-FORCE
Old term used to denote any mechanism assuring a constant transmission of the driving power to the escape wheel.
REPEATER
Mechanism indicating time by acoustic sounds. Contrary to the watches provided with en-passant sonnerie devices, that strike the number of hours automatically, repeaters work on demand by actuating a slide or pusher positioned on the case side. Repeaters are normally provided with two hammers and two gongs: one gong for the minutes and one for the hours. The quarters are obtained by the almost simultaneous strike of both hammers. The mechanism of the striking work is among the most complex complications.
RETROGRADE
Said of a hand that, instead of making a revolution of 360░ before starting a new measurement, moves on an arc scale (generally of 90░ to 180░ and at the end of its trip comes back instantaneously. Normally, retrograde hands are used to indicate date, day or month in perpetual calendars, but there are also cases of retrograde hours, minutes or seconds. Unlike the case of the classical indication over 360░ the retrograde system requires a special mechanism to be inserted into the basic movement.
ROLLER TABLE or ROLLER
Part of the escapement in the shape of a disc fitted to the balance staff and carrying the impulse pin that transmits the impulses given by the pallets to the balance.
ROTATING BEZEL
A bezel that can be turned. Different types of rotating bezels perform different time keeping and mathematical functions.
ROTOR
In automatic-winding mechanical movements the rotor is the part that, by its complete or partial revolutions and the movements of human arm, allows winding of the mainspring.
on Jan 11, 2010 | Watches
1998 buick regal stereo what are the wire color codes
showgif.do?image=73222
Connector Part Information
12110115
32-Way F Micro-Pack 100 Series (Blue)
Pin
Wire Color
Circuit No.
Function
E1
DK GRN
835
Entertainment and Comfort (E&C) Serial Data Communication
E2-E5
Not Used
E6
DK BLU
1796
Steering Wheel Controls Input
E7-E8
Not Used
E9
LT BLU
1405
Remote CD Changer Common Input
E10
ORN/ BLK
1406
Remote CD Changer Left Channel Input
E11
LT GRN
1407
Remote CD Changer Right Channel Input
E12
BRN
199
Speaker Feed-Left Rear
E13
YEL
116
Speaker Return-Left Rear
E14
DK GRN
117
Speaker Return-Right Front
E15
LT GRN
200
Speaker Feed-Right Front
E16
BLK/ WHT
351
Ground
F1
ORN
640
Fused Battery Feed
F2
YEL
43
Fused (Retained w/KP2) Accessory Power Feed
F3
DK GRN
145
Radio Switched Power
F4
GRY
8
Interior Lamp Dim Switch
F5
YEL
32
Fused Interior Lamp Dim Signal
F6-F10
Not Used
F11
BARE
2011
Remote CD Changer Drain
F12
TAN
201
Speaker Feed-Left Front
F13
GRY
118
Speaker Return-Left Front
F14
LT BLU
115
Speaker Return-Right Rear
F15
DK BLU
46
Speaker Feed-Right Rear
F16
Not Used
Dec 20, 2014 | 1998 Buick Regal
How to operate a wheel balancer phoenix pwb 1530
Installation
Remove Wheel Balancer from shipping crate and pallet.
Place Wheel Balancer on flat and stable floor.
Install the Safety hood.
Install threaded rod to spin rod extruding from side of the machine
using the hex bolt.
If Wheel Balancer shakes or moves while spinning the wheel, it needs to be bolted to the ground to ensure proper function.
Electrical plug is preinstalled to fit North American 110 volt electrical socket.
Plug into proper electrical socket. Do not hard wire directly to your electrical source. There is no power surge protection on the machine. Please use a power surge protector to ensure your machine is not damaged.
Install the wheel balancer in a dry and safe environment. Exposure to moisture or extreme heat can damage the components inside the wheel balancer.
VISIT: http://www.nhproequip.com/PDFs/PWB-1530-Operators-Manual1.pdf
May 03, 2014 | Computers & Internet
Power steering not working, check power steering fluid and it is full
If you mean it is very hard to turn steering wheel & it wont or barely returns after steering to left or right. Look at bottom of steering column shaft under the hood. It is very common for steering shaft u-joints to become dried & seized up. Spray up both u-joints & rubber rag joint with a good penetrating oil like " PB Blaster" it is magnetic & will lubricate seized u-joints. Be sure to turn all the way left & spray & all the way right & spray. Let sit for a bit then turn wheel all the way left & all the way right. If it gets better then be sure to lubricate every so often. If it doesn't get better you will need to change the steering shaft.
Oct 17, 2010 | 1996 Ford Explorer
I have a 2001 zrx1200 it has engine vibration between 4000 & 4500 rpm in any gear
Hi Tinkerman626, the prime suspect would be a loose motor mount, swing arm or wheel axle, if you recently replaced any wheels or tires check for missing balance weights, and finally it could be caused by harmonics due to a recently added accessory of "ANY" type. Good luck and have a nice day.
Aug 13, 2010 | 2001 kawasaki ZRX 1200 S
Need help with removing back tire on 1987 honda gold wing aspencade 1200 ccs
Well, best to get an Owner's manual, next best, take it to a motorcycle shop if you do not have the patient or skill. If you are changing the tire, you may need to balance the wheel (rim) again which require a skilled expertise.
Mar 22, 2010 | 1987 Honda GL 1200 Aspencade Gold Wing
Measuring Tools & Sensors Logo
198 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
