Question about Bose (321GS) System
Dvd door opens partially, player says bad disc, generally, i think its dirty
  • 321 Answers
I think its could be a door belt problem or something block your mechanism open and clean it and replace the belt an see...
Posted on Feb 07, 2010
My Magnavox DVD reads disc error
QUICK ANSWER
A disc error may be due to having the wrong type of DVD in the player, having a dirty disc in the player or the disc having scratches or cracks. When it comes to the type of disc, it must be compatible with the DVD player for it to work.
FULL ANSWER
When this error occurs, pull the disc out of the player and look at the underside for smudges and fingerprints. If these are present, using a soft cloth to gently remove them generally solves the problem. Cracks and scratches generally require replacing the disc because they prevent it from working.
or try this link..if a popup comes up on the link just close it down.
Step by Step Guide to DVD CD or Game Disc Repair The DIY Video Editor
Dec 17, 2016 | Magnavox Televison & Video
My naxa built in dvd isnt comin on
If dead and will not respond or door will not open etc it may be a power supply issue in the DVD unit.
If it does open or close but will not "read" or "no disc" etc it is either a dirty or bad optical pickup.
In most cases if the unit is bad (DVD) it is cheaper to just buy a player and hook it via the rear audio video jacks...............
May 22, 2012 | Televison & Video
Disc error
It means either the optical pickup trying to read the disc is dirty or bad.
If bad--it may not be cost effective to repair that unit.
Apr 03, 2012 | Vizio VBR100 Blu-ray/HD DVD Player
Hi, my philips dvd player model number dvp3360/05 has stopped reading disks. Wjen it loads a disk instead of going to the start screen it just goes blank and on the LED display it says title. Any ideas on...
There are several reasons why your DVD player would stop reading discs.
1. Bad or dirty lens
2. Bad disc spinner motor
3. Busted capacitors on the mailboard
If you can open up your DVD player. Try to check for these problems.
Mar 14, 2010 | Televison & Video
Dvd slider door won't close.
Hi, is it fully open, or just partially open?
Is it nearly shut but just jammed? If so have you tried inserting a flat peice of plastic and pulling the draw open. You could do this with no power to the dvd player, It might be that you haven't inserted the disc properly and it is wedged in.
Try all this and see how you get on.
Regards - Anthony
Feb 14, 2010 | Memorex Televison & Video
OPEN error stays on when disc inserted
There is a pressure switch that gets pushed down when the disc door is closed. Ether the arm on the switch is busted, the switch is bad or a busted wire to the switch.
Steve
Oct 28, 2008 | Insignia I-PD720 Portable DVD Player
Panasonic DMR-E55 DVD Recorder won't read most dvd-r brands
Hello jancinn,
This might be due to a dirty pickup or scan laser head, or the optics as a whole might be going bad (both are common problems). A qualified TV repair person should be able to determine if the scan laser or pickup head are bad by doing a laser power test. If the optical devices are dirty it is just a simple matter of cleaning them with a DVD cleaning disk, however if the optics are bad, then replacing them is actually cost inefficient, and you may want to think about getting a new DVD player/recorder.
I hope this helps,
Thank you,
Shuttle83
Jun 02, 2008 | Panasonic DMR-E55 DVD Recorder
Durabrand pdv-702
changes are good that there is a disc stuck in the dvd player
Aug 24, 2007 | Durabrand PDV-705 Portable DVD Player
Bose (321GS) System Logo
79 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
