Question about JVC KW-NX7000 Car GPS Receiver
Jvc kw-nx7000 not working after I tried to update the firmware
I have a jvc kw-nx7000 and i had tried to update the firmware and now my GPS has no signal. I have called in to the customer service line (Canada) and they were not very helpful. They told me to try several things but none of them worked. Now they want me to send it to a jvc service center.
i dont want to pay jvc to simply reset my unit.
Does anyone else have any suggestions?
i used a 2gig sd card and was preformated to fat32.
once the installation process started my screen turned blue and a gps update begins. A cursor spins, than it says retry.
now I dont have any GPS signal!
I have tried to unplug my car battery with the hopes that it would reset the unit.
Here is what jvc told me i should try but didn't work:
turn off the unit
take key out of ignition
wait
turn on unit again and try the installation process again
please help!
I just performed the update as well and ended up with the same issue. I'm hoping to drive my vehicle around to see if it will eventually detect the satellites.
I might recommend a couple of things. Not sure what JVC Support has recommended but you can try a hard reset. Button is located on the left bottom corner of the unit.
You could also attempt a factory restore. The option is located in the settings under your navigation menu.
Overall I like the unit as it seems to be a stable system., for customization and information related to what JVC considers to be propritory info absoultely sux!!! The backgrounds are hokey and screens could really use an overhaul. I have yet to find any really great solutions for working with the files and information and have started to learn on my own. Very slow going so far as I really don't want to brick the unit. If you or anybody else has a good solid recommendation other than the obvious for working into the file structure etc... please feel free to share!
Posted on Apr 20, 2010
There is a little button on the bottom right corner use a pen that is a reset button
Posted on Oct 15, 2011
Problem with JVC KW-NX7000 Car bluetooth and gps messeage.
The bluetooth headset may not be compatible for the GPS reciever.. Check for the configurations for bluetooth.. and then install..
Apr 01, 2012 | JVC KW-NX7000 Car GPS Receiver
JVC KW-NX 7000, the spring loaded latch for the detachable face is broken so the face plate will not stay on therefore I cannot use my unit. Can I buy a new latch for this and if so where or do I have to...
If you still need help on the display faceplate, check this guy on ebay, he has all the jvc parts, I bought my faceplate touch screen from him, his user id is genecyrus on ebay NAU0005-001X
Oct 18, 2010 | JVC KW-NX7000 Car GPS Receiver
My jvc kw-nx7000 is not working what do i do?
Check wiring. If all OK, then call jvc service location
Jan 16, 2010 | JVC KW-NX7000 Car GPS Receiver
I have downloaded the firmware updates to my sd card but it will not finalize, it keeps saying retry after going through the setup and resetting process. My gps says lost signal. Please help.
Are you following the instructions posted on the same place? If not download, print, and follow the instructions. http://resources.jvc.com/Resources/00/01/32/63.PDF
Hope you are not using SDHC (higher than 2GB)
Dec 27, 2009 | JVC KW-NX7000 Car GPS Receiver
JVC KW-NT1 GPS not working in UK
Have you tried re-flashing the unit with the latest EU firmware update available from the JVC website? http://www.jvc-victor.co.jp/english/car/support/navi/nt1/eu/index.html Should overide the current firmware then allow you to use UK maps. If it doesn't work you can always reflash it with the USA update.
Nov 28, 2009 | JVC KW-NT1 Car GPS Receiver
Jvc kw-nx7000 parking break by passed still no video
Connect the parking break as recommended. Then check whether the video appears when parked. If not, send it for service. If yes, then the bipass was not done correctly.
Sep 08, 2009 | JVC KW-NX7000 Car GPS Receiver
KW-NX7000 NO GPS SIGNAL OUT OF THE BLUE
check these options
BAUD RATE AND PORT are set correctly. most gps now have a search function which selecvts the correct options. If not consult manual
Check battery capacity as this is a major factor too low wont pick up signal. freplace if necessary.
claer view of the sky.. not inside
Could even be more serious than that burned out chip and that;s expensive to repair
Jul 23, 2009 | JVC KW-NX7000 Car GPS Receiver
KW-NW7000 "lost GPS signal"
New FW 1.3.4.0 is posted as of Sept 2009
Jun 27, 2009 | JVC KW-NX7000 Car DVD Player
KW-NX700, constant "lost gps signal" all of a sudden!
Hi,this problem exist because the navigation is bloqued, if reset the problem is the same.
The solution for this problem is:
desconect de battery car, and wait 15 minutes
conect the bactery, work`s fine
cumps
Luis Gabriel Portugal
Lutrónica
Dec 12, 2008 | JVC KW-NX7000 Car DVD Player
JVC KW-NX7000 Car GPS Receiver Logo
1,420 people viewed this question
Top JVC GPS Experts
Are you a JVC GPS Expert? Answer questions, earn points and help others
