Asrock 775 vmb Motherboard
I got a computer with this motherboard but it won't start. The computer turns on, the fans work, but nothing is displayed in the screen. Help please. Rubdar
    President:
  • 2,351 Answers
Sorry randar, I need more information about the board. You can look here at Asrock's link.
http://www.asrock.com/support/download.asp?c=775
This pade shows all their Socket 775's.
Now you understand why I asked for more info!
Posted on Feb 21, 2008
  • 83 Answers
YOUR VIDEO CARD MIGHT NOT BE PROPERLY INSTALLED...TRY ANOTHER MONITOR...IF NO LUCK, YOUR VIDEO CARD IS EITHER BURNT OR NOT WORKING.
My computer crashed and when I try to diagnostic the problem with the TechAID diagnostic Card of Soyo, it tells me that FF is not functioning. After that I bougt a new processor for socket 775 and I turned...
sounds like a faulty motherboard. try testing the motherboard after removing everything apart from the cpu and ram then add one piece at a time to eliminate one thing at a time.
Feb 14, 2014 | Asrock Computers & Internet
My new asrock p43de3 motherboard dont wana start and i dont know why please help
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 16, 2011 | Asrock P43DE3 LGA 775 Intel P43 ATX Intel...
Hi! I just made a cpu swap on my asrock p4 combo from socket 478 - 775, the new cpu is the 570J 3.8 ghz 800 mhz fsp 1 mb chache ofcourse i looked at the manual and changed the jumper settings from...
According to the Asrock site, the CPU you chose should work in your board. You are going to have to check the jumper settings, (see the manual page 11) jumpers J1,J2,J3,J4,J5,J6,J8,J9,J10,J11,J12,J13,J18,J21 only. You indicated that you also changed J7,J14,J15,J16,J17,J19,and J20 since your statement was "i looked at the manual and changed the jumper settings from J1-J21"
Also make sure you do not have a jumper block on the CLR CMOS down near the battery. If you left a jumper on, it will not boot
Also, make sure you installed the CPU correctly and did not accidentally bend a pin on the underside. see 2.2 on page 12 Installing the 775.
Dec 23, 2010 | Asrock P4 COMBO...
Cpu fan
no, the fan is for a socket 775 cpu, you have a socket 478 cpu so the bracket will be different
Apr 17, 2009 | Asrock 845GV (P4I45GV) Motherboard
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
Jan 07, 2009 | ASUS P5VDC-X Motherboard
Hello I have a motherboard Asrock nothing works
check all possible connections from your power supply to the motherboard.
May 28, 2008 | Asrock M266A Motherboard
Motherboard
Something is wrong with the power supply.. there might be a blown out mosfet
Apr 08, 2008 | Asrock 775i65GV Motherboard
Asrock dual core 775 vsta motherboard
Since the only thing connected is the power suppy and the CPU, this is often caused by a power supply unable to provide the power to the MB. You will need to swap out the power supply and that should take care of the problem.
Jun 22, 2007 | Asrock 775Dual-915GL Motherboard
Computers & Internet Logo
3,710 people viewed this question
David Payne
David Payne
