Question about Nintendo Wii Console
It wont turn on...I unplugged it and took all the wires off and plugged it back onand still doesnt work.
  • mrhdkh Feb 05, 2010
    I just bought it this Christmas can I return it to the place I purchased it from???
  • 158 Answers
Try leaving it unplugged for 24 hrs and then rehook it. mine will occationally do this and that is what works for me. you should have a 1 year warranty from nintendo. call them.
Posted on Feb 06, 2010
  • 281 Answers
The first thing you should try is another power supply. If this does not fix the problem, then there may be a cable loose. Contact Nintendo and see if the unit is still under warranty.
Posted on Feb 05, 2010
  • Dillon Millsap
    Dillon Millsap Feb 08, 2010
    Most places are 30 day, but you can try your warranty at Nintendo.
Took washer apart, put it back together and now it won't start
ok... seems that it is trying to fill but wont...first...for all problems after dis-assembly of anything...I always recheck all wire connections...yould be amazed how a wire can be pulled off and you not notice it...next...if they are all tight...next ensure your water supply is turned back on at the faucet....try unplugging the unit from the wall, waiting 5-6 mins and plug it back in..to see if the controls reset..phillip
Jul 04, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
My HK AVR 135 wont turn on. The orange light comes on but when i try to turn it on it does nothing. It has done this before and i ust unplugged it and plugged it back in and it turned on for a brief period...
Try unpluging the unit for atleast 2 hrs. The capacitors bleed off energy very slow, thats why it needs to be unpluged for a couple hrs. If that doesnt work it usually means the powersupply is going out.
Mar 30, 2011 | Harman Kardon AVR 135 Receiver
Buick 3800 wont start help
Change plugs check wires for correct connection. Check pcv for vacuumn leaks. Starter fluid on mass air flow meter may damage it.
Sep 30, 2009 | 1998 Buick LeSabre
When i turn the power on the green power supply light goes out and doesnt turn onand the computer wont turn on
Follow these:
  1. Unplug the computer.
  2. Disconnect the power supply from the motherboard and all other accessories.
  3. Replug the power supply.
  4. Connect the green wire (PSON) of the power supply by way of a jumper wire to any black wire (ground).
  5. The power supply should turn on with its fan. If not, it is defective and should be replaced.
  6. Check the ATX12V connector of your motherboard. It is were you removed the 4-wire, 2 yellow and 2 black, connector of the power supply. Check the continuity of the yellow wires to the black ones. It should be open, otherwise it is shorted and your processor is defective and should be replaced.
Aug 19, 2009 | E-Machines Emachine T5026 power supply **...
Wont start up
well from my experience the little colored wires are the power supply they go to box with all the other wires that look just like it will go to cdrom or dvdrom they only go on one way the wide multi wire goes to hard drive this looks just like the ones that go to your cdrom. they could be different thickness some have twice the wire's the big key is the multi ribbon has a color wire on one side that the side that faces the power line. first you need to boot in to bios by what ever your computer tell's you to do. once your in bios look and see if it lists your hard drive. if it lists it as your secondary drive on your primary socket you need to unplug the thick cable at the hard drive and plug it back into the other connector on the same ribbon. on really old computer's than run windows 95 you would have a real little 3 or 4 wire connection that goes from the HD to a spot on the mother board.
Mar 17, 2009 | Compaq MS Windows XP Home Edition for PC
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
Toshiba TN55X81 Wont turn on but I hear clicking
Pull the three connectors to the yokes on the convergence board. If the set powers up, it's a good chance the STK392-110's need to be replaced. I fixed one today, and it has been running for 6 hours now.
-Dan
Jun 15, 2008 | Toshiba TN55X81 55" Rear Projection...
Broke!
Try manually reseting the player:
press and hold the Select button while pressing the Volume Up (+) buttons simultaneously.
Also, after doing so, try connecting it to the computer, and leaving it for about 5 mins to see if you can get a charge. Then turn it on, if that works, you just need to charge your battery.
if that doesn't work, return and exchange it since you just bought it.
Mar 28, 2008 | SanDisk Sansa MP3 Player
Computer wont start.
What happen if not waiting for 10/15 minutes... a bit details will help the support.
Sep 18, 2007 | Medion M3 Composer 5100 PC Desktop
Nintendo Wii Console Logo
114 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
