Question about LG WM2688HWM TROMM SteamWasher
It's showing LE code - LG WM2688HWM TROMM SteamWasher
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 42 Answers
Is your motor spinning at all, if it is slow moving then you have a problem with your stator assembly...........need to replace a part for your stator............
just email me and i'll give you more info.........
drsn777@hotmail.com
Posted on Feb 13, 2010
My washing mAchine is broken?
code le = thermal overload protection
let washer stand for 30 minutes then restart
if code persist call for service
page 28 user manual
Sep 27, 2015 | Kenmore Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
Have a top loading Kenmore elite high efficiency washer model 796.2927, 2 years old this thanksgiving is showing erroe code LE? what do i do to fix?
On most Kenmore front load washers the LE error indicates a LOCKED MOTOR ERROR. This can be caused by:
  1. Loose motor harness connection.
  2. Failed HALL SENSOR.
  3. Failed STATOR.
  4. Failed ROTOR (cracked magnet).
Nov 06, 2012 | Washing Machines
It shows a LE code
Hello.
The code showing at the front of the screen of your washer means the below explanation.
The L means LOCK and while the
E means ERROR.
However what the washer is saying is that you need to lock up the door of the washer properly then the problem of the LE will be solve .
Thanks.
Nov 08, 2011 | Washing Machines
The code LE shows up on the dishwasher and then the cycle stops
Is it an LG. LE is usually a motor code. Enter your model # and code in a search to see specifics. this should give you a good idea as to what you are looking at. Possible problem from your description are motor, control or harness.
May 04, 2011 | Dishwashers
My daewoo washin machine shows error code LE & it wont work actually whats the problem ? tq
my daewoo washing machine has error code LE
after every wash , it cannot rinse and spin then show
beep sound and show code LE. Thank you
Oct 06, 2010 | Daewoo Washing Machines
Code "LE"
Here is a tip that will help you understand the LE code...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 21, 2010 | LG WM0642H Front Load
Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
Sep 14, 2009 | Washing Machines
LG washer code LE or IE showing up
LE Code continues to appear. What does this mean and how to fix problem?
Pete
Nov 18, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
104 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
