Question about Dryers
No heat in dryer . the drum turns but there is no heat in dryer. does no dry clothes
    Problem Solver:
  • 5 Answers
A few things you do yourself:
Be sure to double check the setting on the dryer. It's a "duh" thing, but sometimes people forget that they've turned the dryer temp down to a delicate load.
Check the panel box. Electric dryers require 240 volts to run properly, which means they have a 40-ampere two-pole breaker. If one of the breakers trips or goes bad, the dryer has enough power to run but not enough to produce heat. You may need to replace the breaker to prevent this from happening again.
Check the outlet with a volt meter, on the 220 read-out of the meter! As said earlier, electric dryers require 240 volts to run. If there is not enough power to the outlet, but the breakers are fine, then there is a problem with the wires in your house. You will need to call a licensed electrician.
Check the thermal fuse. Depending on the type of dryer, this fuse will be located either in the front of back of your dryer. (Check your appliance diagram.) It is usually an inch long and mounted in white plastic. Test the fuse using a continuity meter. If the fuse has been blown, replace it.
For electric dryers, locate the heating element on your dryer and test it for continuity using a continuity meter. If it is not working, you will need to replace it.
If in doubt remove it and take it to a local appliance parts supply store. They are usually helpful with that. They can tell you if any parts are bad, and can give you a new one right away!
Posted on Feb 05, 2010
  • Dryers Master
  • 8,404 Answers
Gas or Electric?
Electric - it is possible that the element is burned out. You will have to remove the back for access. Make sure you are disconnected before you test anything..
Gas - is yours a pilot fired or igniter? Pilot - check the thermocouple. Igniter - is it intact?
Thanks for your interest in FixYa.com
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
Dryer doesnst dry
Is the drum turning? Open the door and press in on the switch and start her up. See if the drum turns is what I would try.
How to get inside and diagnose with videos and more for American dryers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 30, 2012 | Dryers
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
Taking 2 to 3 hours to dry a load of clothes...checked dryer vent from dryer to outside and it is not clogged.. what can the problem be?
Are the clothes hot when you take them out? If not, then maybe your heating element is broken. Easy to replace that, just pick one up from a parts store.
Our dryer started to take a long time to dry clothes but the heating element was working. We opened it up to check for lint and so on, and it turned out that the drum had slipped slightly out of location and the back of the dryer was partially obstructing the duct. That was probably what was making the dryer squeak, too. We reseated the drum easily in a few seconds and now it dries well again.
Feb 18, 2011 | Dryers
Dryer comes on, dryer turns, dryer heats but does
make sure your vent is clear from dryer to outside the house.your keeping moisture in dryer and if it cant circulate the air out correctly your clothes will take forever to dry.
Mar 10, 2009 | Dryers
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Gas clothes dryer not drying clothes
could be an ignightor problem reply and we can talk
Jan 03, 2008 | Dryers
Dryers Logo
Top Dryers Experts
