Question about Naxa Electronics NX142 MP3 Player
Power problem with Naxa nx-142. Won't hold a charge
I am having a power problem with Naxa nx-142. It won't hold a charge, even after it has been connected by USB to the computer or with the charger that connects directly to an outlet.
There is absolutely NOTHING on the small mini driver they put in the box with the mp3 player (at least not using Windows 7)! Where can I actually find a user's and owner's manual for the NAXA nx-142?
My husband would like to listen to his mp3 player while he works out, but I can't even understand why the battery isn't charged :_(
Make sure the player is on during charging.
Posted on Sep 17, 2010
How do you set and turn clock display on naxa nx667
Naxa Electronics NX-667 Clock setting - Questions - Fixya
www.fixya.com > ... > Naxa Electronics > Naxa Electronics NX-667
Naxa Electronics NX-667, clock setting related issues. ... set up the clock time 1: press Source button to turn off unit 2: press Clock button to display clock 3: press ...
Naxa Electronics NX-667 Kd s35 manual - Questions - Fixya
...kd-s35 Press and hold SEL button. Press ^ button 3 times to display H (hour) turnvolume knob to change hour setting, press down 1 time to select M (minute) ...
General FAQs - Naxa.com
Dec 12, 2015 | Car Audio & Video
I HAVE A NAXA NX-671 AND CAN'T FIGURE OUT HOW TO SET THE CLOCK
I got a 671 from jujudeals.com and the exact same thing happened. When I talked to them, they said to first, go into clock mode. While you're in clock mode, press and hold select (SEL). Still holding select, use the Fast Forward and Reverse buttons to change the time. FF will change the hour, REV will change the minute. Hope that helps, and if not, you can contact the Naxa support people at this page:
http://www.naxa.com/newsite/support.html
Mar 04, 2010 | Naxa Electronics NX-671 Car CD/ MP3 Player
Need driver for naxa nx-142 mp3 player
So I got in contact with Naxa's customer support and was able to get the driver file. They emailed it, so I hosted it on mediafire:
http://www.mediafire.com/file/uyu4jnf2vqt/win98%20driver.zip
Feel free to scan it for viruses, but it should be clean, since I got it straight from the manufacturer.
Hope it helps!
Feb 06, 2010 | Naxa Electronics NX142 MP3 Player
I need a driver for Vista. for the naxa nx-142
You can use windows xp drivers but as Windows Vista support is ending in feb. 2010 get windows 7 free here.
ignore the 26 june bit as i got my pc upgraded to win 7 yesterday from vista free and its 3 years old!
Dec 25, 2009 | Audio Players & Recorders
How do i put movies on the NAXA NX-142?
The NAXA NX-142 came with a miniature CD you must use the CD to install the software called AMV converter to your computer. Then run the AMV converter with the NX-142 plugged into the USB port. You can then convert certain videos like WMV files into AMV files which can be automatically uploaded to the NX-142 be sure to choose to upload the videos into the MOVIED subdirectory to help keep things organized on the NX-142 The AMV converter will allow certain settings to be selected. The manual is helpful but the printing is so small that I can't read it even with glasses.
Good Luck
Apr 29, 2009 | Naxa Electronics Naxa Detachable PLL...
Changing the theme on the Naxa NX-142
go to your local audio store they should be able to order you one or google what you need.
Apr 25, 2009 | Naxa Electronics Naxa Detachable PLL...
SET WON T STAY ON STARTING TURNING OFF ON IT S OWN NOW WON T PL
Check the power supply. This kind of sets usually has switching PS. Check the capacitors, common fail of special low ESR caps. It is easy to see if there is some electrolitic content outside the cap. In case caps are damaged replace them with higher voltage, never use normal caps in this PS.
Hope to help you.
Jan 11, 2009 | Naxa Electronics NX-517 Television
Nx 142 4gb memory wont go past loading screen.
I would first plug the unit into the computer and make sure that the unit is fully charged. After that, check to make sure that there are folders, with content (mp3s, videos or pictures) to make sure that the unit has something to load in the first place. If there are and the files don't exceed the maximum capacity of the unit you are most probably dealing with a defective unit. I bought my naxa mp3 player from jujudeals.com so it comes with a 30 day warranty, however I'm pretty sure that the unit itself comes with a 90 day manufacturers warranty, in which case you would have to contact naxa. Either way, you probably shouldn't worry, just get it replaced.
Jan 10, 2009 | Naxa Electronics Naxa Detachable PLL...
Mp3 player naxa nx 124
I have found that mine looses it's memory due to a dead battery. I have to connect it to a pc, format the player just like you would format a usb thumb drive. When you power it back on, it will flash the memory and rebuild the play list. Sometimes, it will loose my music, but all I have to do is load them back out to the player. It's kinda a hassel, but I don't care because I change the songs on it on a regular basis anyway.
Apr 09, 2008 | Naxa Electronics Naxa Stereo AM/FM.MPX...
Naxa Electronics NX142 MP3 Player Logo
411 people viewed this question
Top Naxa Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Naxa Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
