Question about RCA R52WH73 Projection Television
RCA- R52WH74 looks like the tv shows are all 3D. when turned on and off a blue, red and green line appear across the screen. ONLY 1 1/2 yr old.
  • 4 more comments
  • Lov2tri Feb 21, 2008
    No "convergence" option. is this fuse easy to buy and install?
  • Regina_ross1 Mar 09, 2008
    tv shows 3d red and green lines when on or off i've tried using auto convergence it did'nt work i have also tried manuel convergence it to did not work.
  • Lov2tri Apr 20, 2008
    How do I get to this fuse? What part of the TV needs unscrewed? I bought the fuse...just don't know where it goes
  • Claudia55 Jun 05, 2008
    Looks like the tv shows are all 3D. When turned on and off a blue, red and green line appear across the screen. Now it turns off by itself and tries to restart itself and does this for about 3 times. It also looks concave.
  • renny818 Jun 30, 2008
    TV SHOWS ARE ALL 3D WHEN TURNED ON. A BLUE , RED AND GREEN LINE APPEAR ACROSS THE SCREEN, oNLY HAD IT 2 YEARS
  • Chris Kelso
    Chris Kelso Dec 28, 2008
    I have the same problem with my RCA except in addition, the picture is warped. The picture looks as if it's been stretched to the corners of the screen. My convergence option on the menu has disappeared as well.
    Other than fixing the convergence problem, will this fuse solve the warped picture problem as well or is there a completely different problem I'm facing?
    Thanks,
    Kelso
I had the problem with my rca looking like it was in 3d. anyways, I read this post and ordered the part ($3.79). did the soldering and TV works perfect now. Txs so much for the info on how to fix the problem. I was so worried it was going to cost a ton to have someone repair the TV. Much appreciated!
Posted on Apr 20, 2008
Just like the forum says; follow step by step and make sure to re-solder the FLYBACK and this will work! I had to pay a little more than $13 after shipping and cost of Fuse (about $5!!). Don't bother with local TV repairmen, the 10 or so I talked to are very rude and cocky people. Partstore.com was very helpful and quick with ordering, although I had to wait on a RCA Company backorder!! Thanks for the help!
Posted on Jun 12, 2008
    Genius:
  • 1,030 Answers
Do you have covergence in customer setup menu? i fix a common problem with set all the time. if you find there is no "convergence" in customer setup menu then it could be a special small fuse that blows due to bad solder connectiions
Posted on Feb 21, 2008
  • Willie Howell Feb 21, 2008
    ok this fuse is rather small its a small brown rectangular fuse on power board. its a 400 mili amp fuse between two other fuses most of time it kinda hard to get too. You have to know a little about soldering. too. You would have to order it special your local hardware store would NOT have it. rca part number 259213. The main thing is you would have to resolder the conections of the FLYBACK transformer. this is what cause the fuse to blow in the first place
3-d Picture
The vertical deflection output chip or associated cirutry including the coupling cap and controls. Some units have vertical output transistors which can short and open the B+ resistor feeding the transistors.
Oct 11, 2009 | RCA D52W19 52" Rear Projection Television
RCA R52wh74 with 3-d picture
sounds like you have a convergence problem my friend, if you are handy you can Google a kit with all the parts for your set and save hundreds of bucks!!!!
Larry Dillon
Aug 11, 2009 | RCA R52WH73 Projection Television
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
RCA Projection TV Model HD61W66
convergence power supply not working , there is a mini fuse close to the flyback thansformer , 400miliamp at 250 v resolder the flyback and replace this fuse , there is 3 fuses it look like small squer brown color is the one on the middle , normal repair $200 - 300
May 07, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
The colors are distorted and it seems like the only colors that really show are blue, green, and red. When you turn the TV on you can see blue, green, and red lines across the screen. The picture also...
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
3D TV Blues, Greens, Red and a little yellow. RCA Modle # R52WH74
This is called convergence board failure. try to re calibrate the convergence. if the re calibration fails, this means your convergence board will need to be replaced or, rebuilt.
Feb 13, 2009 | RCA R52WH73 Projection Television
RCA 52" TV
Here is your other post.
Feb 25, 2008 | Televison & Video
RCA R52WH73 Projection Television Logo
375 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
