Question about Ariens 34 In. Zoom Series Riding Mower
I cannot get the engine to turn over and keep running. I have cleaned the carborator and checked the fuel lines. Now I have to much gas and it is leaking from the carb and also coming oout of the primer button & line. I have an Ariens ST7-24. Please help.
  • 12,061 Answers
Check you Float Valve in the carburettor. sounds like it is sticking?
Posted on Feb 05, 2010
My l100 wont start but when i put gas in carborator it runs till gas is gone
Not 100% sure but the fuel is either blocked or the line may have a tap that is turned off. Check to see if you have an in line tap that turns 90 degrees, the ears of the tap should be inline with the fuel line, also check to see if the fuel line is pinched or if it was sucked of fuel causing it to collapse. Hope this helps
Jul 15, 2016 | Garden
John Deere GT263 wont start. Wont even fire, turns over OK
DO you have spark?? To check for spark pull spark plug out. With the spark plug connected lay the spark plug on the block of the engine( something metal) and try to start the engine.waych for aspark as the engie is turning over. Does it spark?? If not check the safty switches - Break petal, seat,blade engagemment switch. Also check the coil/magneto.(without the right tester for goil ) you will have to replace the goil. A little pricey. If you have spsrk, the problem is in the fuel system. Is there gas in the tank? Does the tractor have a fuel shut off in the gass line? Is it open?
Close the fuel shut off valve or crimp the fuel line with vice grips or some type of locking plyers. Remove the carborator bowel. Is there gas in it? Yes, Carborator needs cleaning. No, open the fuel line and see if fuel flows out of line. If not check and see if obstruction on line or tank.
Most importantly is the spark/ ignition system. mainly the safty switches and the coil/magneto. If any ofthe safties are open you will not get ANY spark. If the switches are working correctly I suspect it will be the the coil.
May 03, 2011 | John Deere Garden
I have a 261 that will run but keeps bogging and i have to keep flipping the choke in and out really fast but i cleaned the carborator but what else?
Check the fuel filter and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor is firmly mounted to the engine. If no help, then you may need to check the diaphragm in the lower chamber of the carburetor for flexibility, and no cracks or holes. When the carburetor is off of the engine, check the impulse passage behind the carburetor for air leaks--no bad gaskets. Hope this helps!
Jan 19, 2011 | Husqvarna Garden
I have a weed eater trimmer that i replaced the gas lines but now when i pump the top of the carborator no gas gets to the carborator and the trimmer will not start.
REVERSE THE TWO FUEL LINES .. OTHER THINGS TO LOOK FORCHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My 1992 dodge dakota wont run. i will start it but i will have to feather the gas to keep it alive. it has over a half a tank of gas in it can you help me?
when was this vehicle as serviced?
this could one of several issues.
1 the idle jet on the carborator maybe dirty so the engine is not getting enough fuel at tickover to keep running.
2 the fuel filter is blocking up and may need replacment.
3. the carborator may need an overhaul as the float chamber is not activating correctly.
4. fuel cap may be blocked give a run with the fuel cap off see if that helps. if you get aload hiss each time you fill up that indiates a blocked fuel cap which will need clearing or replacing.
5. dirt in the fuel line if filled from jerry cans contaminents can get in th tank and block the line. when you put pressure on the gas this causes higher vacum from the pump and hides the problem.
6 airfilter may be blocking and needs replacement so there is not enough air at ldle.
7 check plugs if they are sooty or covered in white then the mix is wrong and needs resetting. or indicats reduced fuel or air to engine.
8. plugs may need replacement.
Nov 13, 2009 | 1992 Dodge Dakota
I have an 88 ford broncco 2 eddie bower edition and i have replaved both fuel pumps and it still wont start unless you pour gas into the carborator then when the gas in the carborator runs out it dies
you may have a gold coloured filter that screws into your carb. Unscrew it and check to see if you can blow through it. It may be clogged. Also you can check for fuel at carb by loosening the fuel line going into the carb. Crank engine after loose. Should have gas coming from it.
Oct 20, 2009 | 1988 Ford Bronco II
TB20CS gas trimmer, primmer bubble won't pull in gas
The carburator has a sereis of one way check valves that get cloged very easily.
If you remove the carburator and clean it out with a simple cleaning solution you should be able to clean it up.Do not use compressed air.
Aug 03, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Fuel
the fuel filter sounds like the problem, are you sure its carborated not fuel injucted because fuel injuction has a regulater for the fuel if it is stuck open you would pump gas to the fuel rail and back to the fuel tank
Dec 23, 2008 | 2000 Oldsmobile Bravada
Carborator not getting gas
If you have fuel in line make sura how is your fuel filter, if the fuel fiter geting fuel from the fuel pump then and no fuel coming into carburator remove the head part of the caburator some scerws on then taked out you will see foult chamber remove the flout chamber careful needle valve coming out then take screw driver remove needle holder then you will see filter which is blocked fuel to inter the caburator.
1- you need kit of caburator parts you can get new filter.
change all gaskets top and poton of the caburator.
Dec 03, 2008 | 1990 Toyota Pickup
Ariens 34 In. Zoom Series Riding Mower Logo
204 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
