Question about HP OfficeJet 6210 All-In-One InkJet Printer
How to use with ansering machine : can I setup an ansering machine on the same phone line as my hp officejet 6210 all-in-one
    President:
  • HP Master
  • 2,017 Answers
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Have a nice day and do not forget to rate please...!
Posted on Feb 06, 2010
  • 4,041 Answers
Hi
Yes I use the same line for Fax. But my printer not same as yours.
I have just put on my website to download for you.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/HP-OfficeJet-6200-6210-Manual.pdf
You will need an adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 05, 2010
Will the HP 6210 work with VOIP and Win 7?
HP Officejet 6210 All-in-One is not tested on VOIP connections when it was in manufactured. However these printers do work with VOIP connection.
If you are unable to get the printer working on VOIP connection, there are few ways to fix this.
1. Reduce the Fax speed of printer ( from Setup - Basic Fax Settings - Fax Speed ). Try to Fax
If this does not work, try the step below
2. VOIP is Digital technology and HP 6210 works on Analog Signals ( standard telephone line )
- You need a DSL Filter which converts the Digital Signals to Analog and vice versa. This filter is available at any departmental store or computer accessory shop
- Connect the DSL Filter to phone socket. Connect the printer telephone cable to Analog port of DSL Filter ( to Line 1 Extn port of printer )
Either of this should fix the solution. However there is another solution which may or may not be possible. It is to reduce the baud rate on your Cable connection ( though not recommended )
Regards,
Shawn
Jan 28, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Fax is not receiving or sending.
Embarrassingly simple. Ran a test fax per the manual ( press setup button; press 6; press 5), found that the "an active phone line was not detected," and discovered that the phone jack was not secure.
Oct 08, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 6210 All-in-One - Conformation Page
yes
press setup
pres 2 and then press 1
this seletcts print report and then select Fax Report setup.
press and scroll to the to the report type you want.
press OK to select the report
Jan 08, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Fax/ printer 6210 set up
Please see bellow is the diagram mentioned in the link bellow on getting stated up with your kind of setup:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50333&cc=us&lc=en&dlc=en&product=421991
Good Luck
Sep 12, 2008 | HP OfficeJet 6210 All-In-One InkJet...
All in one
i have a hp officejet 6210 all in one and my printed want receive fax what is the problem. from mary
Jun 10, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 Error Code 392
Error 392
Unable to complete the handshake.
*Try to send the fax at a different time when telephone line conditions have improved.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&cc=us&lc=en&dlc=en&product=421991
heres the link for all other codes listed with your hp
yes there depends on system you have the fax can go threw after the answering service ended
May 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
How to receive fax on Hp officejet 6200 series
First you should use the manual and follow the fax setup section. These directions will have you click a few buttons on the printer so that the printer knows how to answer the incoming calls.
There is usually a button on the printer named "auto answer" or something similar. If you are using the same phone line to make phone calls then you should turn this button on only when you want the printer to answer the next incoming call.
Also make sure you have the phone line connected to the correct port on the back of the printer.
Jan 03, 2008 | HP OfficeJet 6210 All-In-One InkJet...
I can't fax... Hp 6210
Have you tried to contact your phone line provider? Maybe the is on thier side. If there is nothing wrong with their conncetion then pls click on the link below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&cc=us&lc=en&dlc=en&product=421991&dlc=en&lang=en
If this doesn't help your issue, pls post here and I'll get another solution for you.
Oct 18, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
91 people viewed this question
Seeker5211
Seeker5211
