Hi there ive bought a alba as122 surround sound and ive connected all the wires, however can you plug the wires straight into the tele as the speakers wont connect to the tele the insructions arnt the clearest, thanks
  • 88 Answers
You can use a switched scart to phono adaptor or if you have audio out phono sockets on your tv use them as an input to your alba sound system
Posted on Feb 05, 2010
Control
I have lost my remote control for the alba 3.1 Active Home Theatre System Model AS122 can you tell me where I can get a replacement
Jul 13, 2013 | Alba Remote Controls AS122 Subwoofer...
Sound has gone on alba 32inch tele when i tap the bottom left it comes on for a second then goes straight off again.
Either the headphone socket has poor contacts or you have a dry joint on the audio board. Resolder the components that are mounted on heatsinks.
Hope that fixes your TV.
Nov 16, 2010 | Toshiba Televison & Video
Hi. I have an ALBA LCD32880HDF television which I purchased in August 2009 so just outside warrenty. I have been on holiday for a week and had switched the television off at the wall and returned home...
hi all the black screen solution for me was this (this is assuming you have alba brand tvs and have the black screen BUT can still hear the sound) i after much fekkin around with it eventually found the solution in it (its the bloody backlight brightness in the settings you need to turn it from high TO LOW) ....... now this can be a bit tricky because usually when you have the black screen problem if u unplug the tv for a few hours and plug it back in you only get or should get probably like 30-1min of picture time before the picture goes black so u have to be reallllly fast with the menu button to get into settings before the picture dies (i learned the sequence for my alba lcd32880hdf) it was the following (for this part use the remotes arrows the one with the ok button usually in the centre of them) turn the tv on then click menu then press the up key 2 times then press ok then use the right arrow/button twice (although u cant see what ur doing ur navigating the menu hehe) then press the down arrow/button seven times before finally pressing the left arrow/button (once) <-- (now this bit may need to be done twice if you can remember setting ur backlight to max use it twice it will put it on minimum if in doubt only press it the once remember to totally power the tv off before repeating the steps to reset menus default posistions) remember thats the solution i found for my tv stands to reason (since i did infact buy another tv same brand different model which got the same problem) that this could be a solution for all alba tv users try it worked for me 2 times if ur not sure of the menu look up you tv models menu navigation online to find out the buttons you press gl hopefully it works for you too
Oct 24, 2010 | Televison & Video
I bought an Alba CDVB4 and the remote isn't right
Hi
Not sure if you found the problem for this, but I had the same problem and couldn't find any reference to this except your question so thought I would put up an answer in case it can help you or anyone else.
Aparently, Alba have got hold of the codes that Toshiba use for their remote controls, so if you have a Toshiba telly an Alba product like this won't work. The only solution being to return it and get a different make.
I returned mine twice for a straight exchange thinking it was just a manufacture fault before I found this out. I then exchanged it for a Bush set top box - only a fiver more - and it now works PERFECT!
I hope this helps some.
Zoe
Dec 04, 2009 | Televison & Video
Technics
are you trying to use the surround sound for movies or music ? , ive got the dvd version of this system (sc-dv290) and ive noticed the surround sound tends not to perform well with music , but sounds great with movies. i think its because the movies have dolby digital and music does not. The dolby pro logic in my opinion doesnt really make that much of a difference in sound unless the sound is cranked up past 44db on the amplifier. the only cables you need are the ones that are attached to the surround sound speakers and they cannot be removed so it cant be the wiring . I reckon you have a 1 - faulty system 2 - listening to music 3 - maybe not pressing the pro logic button on the sound processor. Hope this helps
Sep 11, 2008 | Technics SC-DV290 System
Buzzing in speakers of cinema surround
i have the same problem. haven't tried the fix yet, but someone recommend connecting the two pronged power cord to an adapter that switches it to a 3 pronged (adds the ground prong). i guess the adapters are less than a dollar and can be bought at most places.
Dec 04, 2007 | Audio Players & Recorders
Rf2 outlet from sky hd box
on your sky remote
services
0 1 select
make sure the rf is set to on
Remember the channel rf number,
go to your television the link is to.
go to menu then setup and then manual tune
select the channel you want to view sky on. normally channel 6 on your analogue
then go to Channel type in whatever the rf setting was on your main sky box then press save.
that is your telly sorted out. if you have a magic eye connected at the link end you should see a red led light lit up.
if not remove the magic eye and connect it straight into the back of your sky box RF2
just to make sure that the eye is not at fault.
hope this helps
ill check in a day or two to see if you need more help.
Cheers
Little Dish Fitter
Nov 14, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Getting playstation 3 sound coming out of dvd surround
This wont be very helpful, but, it is worth noting that although you may think you bought a "Wharfdale" product, i'm afraid you haven't. Chan bros. bought the rights to the name some time ago and so what you have is a cheap non-descript chinese import. sorry.
Oct 04, 2007 | Wharfedale DVD-M3 DVD Player
435 people viewed this question
 Grubhead
Grubhead
