Question about Goldstar GVR-E435 VHS VCR
Black and white only when playing a DVD or VHS hooked up to my Sony Bravia 32" LCD TV.
    Scholar:
  • 50 Answers
What type of connections are you using?
If you are using coax cable check to make sure that the TV is on the proper channel that the DVD/VCR is switched to i.e. 3 or 4.
If you are using Componant video (red, green, blue, and red, white) verify that the green is plugged in all the way on both the TV and DVD/VCR and try connecting it to a different Componant input on the TV.
Note: the TV may be YCbCr, and DVD/VCR YPbPr or vice versa these two types usually are not compatible with each other. YCbCr is a digital signal and YPbPr is an analog signal.
If you are using A/V video cables or (yellow, red, white) check the DVD/VCR video setting to see if it is in progressive scan mode, as this can cause a problem with some TV sets that are not compatible.
Posted on Feb 05, 2010
Dark lines running vertically in lcd tv
is problem when u are play with dvd or normal analog signal or digital sinal which one specify if in all your lcd some hardware problem
May 19, 2012 | Sony Bravia L-series Kdl-32l5000 32-inch...
I purchased a 46" Sony Bravia flat screen TV. I
Try going into menu input set up on tv and switch to av input. Just a thought I have the same model and had exact problem. All I had to do was change input style to av cable.
Jan 25, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
We just bought a new 32" panasonic led tv. Hooked everything up and works fine with normal television broadcast. However, we have a Sony DVD/VHS combo hooked up that doesn't perform well. When we play...
If you are using the composite cables (RWY) make sure the red and white are plugged into the audio jacks and NOT the component cable plugs (RGB.) If you have the red audio cable plugged into the red component plug this will cause issues, especially with the sound.
Aug 10, 2010 | Panasonic Televison & Video
Black and White Picture??
If you hook up component from cable box you must hook component in put at TV also.
May 09, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Plays vhs tape in only black and white (no color).
my old series of ROOTS is playing in black and white and says on cover that they are in color
Jul 03, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Screen goes blank / black, sound still works
It sounds like your LCD Screen is no longer working. I would try contacting Sony and ask for a refund. I had the same T.V and the LCD Screen had gone out. A techniction came out and Condemned the screen and i had to pay $500 for a new T.V.
Apr 13, 2009 | Sony BRAVIA KDL-40V3000 Television
DVD is wired to the VCR and does not work
The Sony Bravia should have a number of component inputs, so you should be able to hook up the DVD directly to the TV. The only reason for hooking it up through the VCR would be to record a DVD on VHS... but that's for the birds--VHS is old technology.
Each component input on the back of the TV has a number. You then select to view the component you want by pressing the remote control button to change the display (it should show with one you're on... e.g., Video 1, Video 2, Video 3, etc.).
Dec 24, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
DVD'S Play only in black and white
In UK this occures when an NTSC picture is played from a DVD player to a TV which cannot enitrely hand NTSC format. Possible this will happen in the reverse for USA.
Also my TV cannot handle SVHS signals and also displays them in black and white.
Try changing settings on the DVD Player to Composite or RGB.
Regards
Mar 10, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Bravia and Sony camcorder
how are you trying and what are the results? are you hooking up an analog camcorder to the correct video inputs? (the yellow red white), instead of perhaps the component that will not give you color on comp inputs.
Jul 06, 2007 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
179 people viewed this question
Top Goldstar Televison & Video Experts
 Grubhead
Grubhead
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Televison and Video Expert? Answer questions, earn points and help others
