Question about Saeco Vienna Espresso Machine
I have a saeco italia and coffee is too weak - i have cleaned the grinder, and have adjusted the setting in more ways than one can count. No puck is formed once dispensed. I have also de-scaled the machine. Do you think it could be that i need new burrs.
  • 1,089 Answers
Hi If you don't get the grinder back together correct and have the dials set in the bean hopper before attaching you will not get the correct grind and dosage for strong coffee. Dull burrs will usually give finer grinds but they will clog up quickly.
Posted on Feb 06, 2010
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
I got a saeco italia and the coffee tastes too light. how can i adjust it to make the coffee strong??
Hi
There are 2 knobs in the bean hopper. Turn the big knob to 8 and the small knob to the plus (+), then back one mark. If the grinder is already lower than 8 and the grinds look larger than coarse sugar you might have a seperated grinder.
Dec 21, 2010 | Starbucks Saeco Italia Digital Barista...
My coffee is weak. i have played with the grinder, placing it at different no. on the outside plus i have played with adjustment on the interior.
Hi
Check the grinds. If they are coarse you have a separated grinder. It usually means it needs to be replaced I have seen them on ebay, but if you can't find them, I have some. If they are not coarse, you have to make 3 coffees before the grind will take affect. After you change the grind you have to make 3 drinks before you will see a change. If you don't have a puck in your dredge drawer, you don't have enough coffee going into the brew unit. Push the lever behind the door in the center top back to the +, then forward 1 click, and try that. There should be a full puck going into the dredge drawer that has the consistency of coarse sugar. If it very coarse its the grinder.
Dec 12, 2010 | Saeco Magic De Luxe Espresso Machine
Saeco Italia coffee too weak - grindes too coarse
Remove beans from chamber, then remove the 2-3 screws in the chamber, then lift hopper slightly and turn adjustment knob towards the middle number, or halfway between fine and coarse. Then lower hopper make sure the gears line up together, set screws add beans and adjust finer.
Oct 08, 2009 | Starbucks Saeco Italia Digital Barista...
SUP021 YR keeps getting clogged
go to espressotec logo there you find how you can clean grinder.if still you dont have coffee try explain better whats hapend with machine when you want make espresso,good luck
Sep 04, 2009 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Grinder setting i
0 is the finest setting. If you read the manual, it advises to adjust your grinder ONLY when the grinder is actually working. Also, you should only adjust it gradually from one setting to the next (ei. from 2 to 3), and wait about 5 cups before adjusting the setting again.
Oct 22, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna Espresso Machine Logo
280 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
