Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
I have a 99 polaris sport, and its really doggy from the start until I get moving, and then Im fine. I cleaned the carbs out, changed the fuel filter, replaced the gas with new stuff, and changed the plugs. It idles OK, but could be a little better. What can I do next??
  • James Nowalk Jan 27, 2012
    Did the solution below fix the problem? if not what did? i am having the same problem. Thanks
  • 46 Answers
CHECK THE COMPRESSION IN THE ENGINE, CHECK THE DRIVE BELT ALIGNMENT, CHECK TRACK AND CHAIN TENSION AND THE SECONDARY AND PRIMARY CLUTCHES. THAN CHECK YOUR JACK SHAFT AND DRIVE SHAFT BEARINGS
Posted on Jan 06, 2011
I have a 2003 polaris/330 trail boss with a fuel problem. i had carb rebuilt at a shop .cleaned, new needle & seat installed. new plug, carb vent/ equalizer cleaned, tank vent clean. starts fine, runs...
there's a vent on the carb they might've have missed, the line could be clogged. insects and mud get in them. plus it could be the petcock on the tank. take it out and make sure the screens, are cleaned etc.
Apr 21, 2017 | Polaris ATV
No gas to spark plug on atv
carb float/needle sticking opening the carb drain will provide evidence if fuel is reaching fuel bowl, if fuel is present then i would suspect the carb is gummed up and it will need to be cleaned ( all jets/passages ) another area could be that the gas cap vent/line is plugged not allowing fuel to flow by gravity feed.
Jan 08, 2012 | Polaris ATV
Polaris 500 x2 starts fine, but when you apply
I have a 2003 sportsman 500 ho thats doing the same thing. It starts fine everytime and idles fine but when you push the throttle it stalls and sounds like its loading up with fuel. Also its fouling the plugs when it does this b/c I can take them out and they are jet black (dry). I checked the spark and the spark appears to be good. So now I'm in the process of taking the carb apart to see if there is anything wrong with it and to clean it. If this doesn't fix it then I don't know. I really don't want to replace the coil b/c its like 150 bucks.
Feb 16, 2010 | Polaris ATV
I have an 03 polaris 330 magnum 4x4 it worked fine than one day i had to keep the choke on to keep it running took carb apart cleaned all jets etc started it back up worked fine then it didnt put choke on...
Sound like the needle and seat are dirty. Also check the fuel strainer / filter for debris. Usually if the needle and seat are dirty so is the filter / strainer & bowl.
Needle and seat item(s) 24 and 24 original factory Parts manual under carb. at the dealer:
(called float valve in description)
Sounds like the float valve is either not closing or is dirty and not allowing carb to fill to the proper level. i.e causes fuel starvation AND carb over filling intermittently. You can clean the needle and still have a bad seat for the needle.
Find and replace or clean the fuel filter also. If your carb has a manifold and nut on the side of it for the fuel manifold remove the nut (actually a bolt type thing) and clean the strainer inside the manifold.
Thanks for using FixYa!
Kelly
Feb 13, 2010 | Polaris ATV
I have an 04 or 05 Polaris Sportsman 700 twin 4X4 that just started to have problems. I was gone for 2 months and when I got back it won't start unless the choke is full out and will only run that way. It...
I had this problem on a 05 polaris sportsman 700 carb... I dissasembled the carb. cleaned it all out... It actually was fine. It turned out the torque of the motor broke the hard rubber intake that connects the airbox to the motor... This part is $60 and takes 2 bolts to change! mjninke@yahoo.com
Oct 09, 2009 | Polaris ATV
Scag SMT61A Mower with Kawasaki 27KA engine. 200
try taking stater fluid to carb and try keeping it running,needle seat might have some dirt in it or the carb itself needs to be cleaned.
Apr 22, 2009 | kawasaki Full Suspension Mountain Bike Men
Need a diagram to route fuel lines on a carb
my polaris outlaw 500 sarted cuting out last ride could not ecerate past 1/4 throtle and was back fireing so went to fix and wont run at all i have spark, plug is wet, changed fuel, seems to have compresion, when it turns over it tries to fire at times more like a hickup almost stops the sarter and a puff of smoke out the carb. im about to tare it down any ideas whats wrong ? bike was hard to start but ran ran perfect killed raptors with ease. bike was bored and built by some shop before i owned using ktm sleave and piston ? motor says nicols 520. didt over heat or make noises. have tried cleaning carb, jeting no luck please help
Mar 17, 2009 | Polaris ATV
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
116 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
