Question about Acer AL1916B 19" LCD Monitor
I can't open the case on a ACER AL1916B monitor,it does not match the Acer service manuals.Other than the base bracket mounting screws,mine has only 2 screws at the bottom of the case. I would like to open the case to facilitate a repair to the power supply.
  • 732 Answers
Refortsm, you didn't say that you looked at any video clips on YOUTUBE that deal with LCD monitor disassembly. Find very , very DULL butter knife or table knife. You do not need a trip to the "ER" for a self-inflicted stab-wound!!! Some use old cd rom disc's for release of perimeter locking tabs???? Protect the units glass LCD panel at all times. You crack-it, then it's "You bought it you own it toyota!" "game over" for you. Removal of rear cover is hardest part of unit "tear-down" and inspection. Key for you is START at bottom with B-knife and pry gently. I hope this helps. Let me know about your "switch-mode-power-supply" condition. lmistyrel on aim. or 12fixlouie on Fixya
Posted on Feb 06, 2010
Is it possible to rotate the screen (acer al1715sm) from its base? (to srew on the wall) cause mine moves up and done, but gets stuck after a small bit..
find audio multimedia base like VG3P31 (Philips) std. 4 screw mount pedestal like photo below..move up/down, CW, right/left.659ae0f8-3ebc-40d3-ad3a-1dd9b380bafc.jpg
Oct 17, 2013 | Acer AL1715 Monitor
Remove stand from monitor
there will be screws on the back which will allow you to remove the stand, then on the back of the monitor their should be 4 screw holes, use these to attach a a flat plate wall bracket to it.
but if you can't remove the stand, then put a clap speaker bracket on the wall & just clap the base of the monitor, as this type of bracket can be adjusted both in & out & up & down.
Jul 21, 2012 | Acer AL1711 17" LCD Monitor
ACER LCD monitor has no power.
It is probably the inverter which powers the backlight. It should say inverter right on it.
Feb 08, 2010 | Acer AL1916B 19" LCD Monitor
Well my ACER AL1916B LCD monitor blew up.
The MOSFET that blew up will more likely to have the switch mode driver IC that went out with it also, you need to verify that the IC is good otherwise you will blow up the new MOSFET, you may be better off buying a new board from here: http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1160140&Click=54985
By the time you order the new MOSFET and other parts it may end up more han $35, just a suggestion.
Feb 04, 2010 | Acer AL1916B 19" LCD Monitor
How do I remove the back from my acer al 1916W
face down the monitor over a soft surface to avoid scratches .Remove all screws that you can see.There are more screws that mount the leg to the monitor .Those are hidden you can not see.Covered by a little plastic cover shell.After you remove all the screws ,now you need to remove the back cover from the monitor .using a flat screw driver or another slim tool begin from one side .stick the screw driver into join line between the front and back cover and twist it gently.this is hard part of the operation.You got to be careful .try to loose one side first then other sides ll be easier.
Apr 06, 2009 | Acer AL1916W 19" LCD Monitor
Tilt new monitor???
mcdevito75 here, I also have an Acer and it Doesn't tilt, that doesn't mean yours won"t, try to hold the monitor by the top and simply try to tilit it while makeing sure the base stays flat on the desk, (table) don"t force anything. Also look for any kind of screw, or handle connected to the base (bottom) or near bottom of back of monitor. Hope this helps. Oh! also check the manual that came with the monitor, mine has no mention of tilt. Sorry.
Jan 18, 2009 | Acer X191WSD Monitor
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
Oct 26, 2008 | Acer AL1717 17" LCD Monitor
How do I open cover of Acer AL2021 Monitor ?
This is a bit tricky, but not impossible.
1. Remove the two visible screws near the bottom. 2. Pull the plastic covers off the stand: Pull from the inside (nearest where the stand is attached to the monitor. 3. Undo the screws and remove the bracket. 4. Under the bracket is the final screw. 5. Try pulling the front off the back starting at the bottom. It'll require a little force. 6. Now you should be able to get a knife in to pull the rest of the case off. Leaver by pushing the front outwards and back inwards and the clips should come off ok.
Aug 06, 2008 | Samsung SyncMaster 550S Monitor
White turns to pink on acer laptop
I had the same problem but the white color became cyan.
I "solved" the problem hiting the back of the monitor. I think that is a problem of contacts between the signal of the monitor and the pc.
I have an acer 5610z.
Juan Pablo.
Jul 28, 2008 | Acer AL1916B 19" LCD Monitor
Acer al1916b high pitched noise when on standby.
Sounds like you could have an open ground? Also might check the wiring to see if you have a faulty connection in VGA cable or power supply cable
Jul 24, 2008 | Acer AL1916B 19" LCD Monitor
Acer AL1916B 19" LCD Monitor Logo
317 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
