Question about Dryers
How do i know what wire goes where when I replace my 3 prong plug with a 4 prong plug. Kenmore dryer 80 series
    President:
  • 949 Answers
You should not do this. Sorry, but you also need a 4 prong outlet
that has the two hots,one neutral and one ground, so if you don't have
the right outlet with these four wires you can't change the plug.
If you did change this you also need to remove the ground strap
that is connected because it has a three prong plug.
There is a connection board where the wires connect on the dryer,
there should be a black wire,red,white green,connected from dryer,
then the cord gets connected to each corresponding wire.
I am real sorry, but if you do this wrong, you will either destroy the dryer
or electrify the dryer and get killed.
Please call a electrician and have him check your supply line and do this, its not worth getting hurt or wrecking the dryer just to save some money.
Posted on Feb 05, 2010
  • odiebugs
    odiebugs Feb 05, 2010
    Yes, solution 2 is great, but it tells you nothing about the supply line that you need. Please call someone.
    Top Expert:
  • Dryers Master
  • 77,499 Answers
Read the help article at the link below.
http://www.ezdiyelectricity.com/?p=221
Or all blower motors on electric kenmore 80 series 220 or 110 current
Speaking of these United States, here's how that goes.
In this country, dryers are called 220, but they are really 110 twice!
So, on the back of the dryer is a plug with 3 or 4 prongs.
( hope you can get this from my description. )
On a 3 prong plug, the two "slanted" prongs are each hooked to 110 volt p service.
The "L" shaped prong is a ground.
If you have a 4 pronged plug, the two flat straight prongs are 110 volt each, and the "L" shaped and the round prong are both grounded.
FYI: Each of the 110 volt wires has a different function. One powers the motor, the other the heating element.
Be Blessed.
Jan 23, 2013 | Kenmore 659 Electric Dryer
I need to change a 3 prong to 4 prong on a Kenmore 800 series dryer. I know where the green ground wire grounds, but not the other 3. :)
Either way, plug or dryer cord the white wire goes with the green wire, they are pretty much the same. On the dryer at the block where you are connecting the cord, look just above it and you'll see wires coming into it, the red and black are on the outside, I'm not sure which color on which side but the white and green go in the middle on top one another and the red and black match respectively.
May 26, 2012 | Kenmore Dryers
NEED TO KNOW HOW TO HOOK UP A 4 PRONG CORD TO DRYER WHAT COLOR GOES WHERE
The following link explains how to properly connect a 4-prong power cord on your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have any questions, please post back and let me know. I hope you find this helpful.
Oct 07, 2010 | Kenmore Dryers
I am going from a 4 prong to a 3 prong i do not have the manaul for the dryer and the 3 prong plug is not color coded there are 4 conectors and neutral on the dryer the 3 prong wire has 2 conectors and a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 02, 2010 | Roper REX4634KQ Electric Dryer
Kenmore dryer surface gets extremely hot when
Classic of a clogged vent to the outside, Air out back of dryer should be same outside. Dryer will get hot and take to long to dry clothes with a clogged vent. Pls leave a FIXYA rating.
Aug 24, 2009 | Kenmore 63942 Dryer
We have a kenmore 70 series electric dryer, and we have a three prong receptacle, but the plug is 4 prong. What type of adapter do we need?
According to the National Electrical Code, as of 2000 all newer homes are required to have a 4-prong receptacle for all 220VAC appliances. However, if your home already had a pre-existing 3 prong outlet, you shouldn't have to upgrade to a 4 prong. The following link explains:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
The main difference is how the neutral (WHITE) and green (GROUND) wires are termnated. In a 4 wire configuration, the neutral and ground are independent of each other. In a 3 wire configuration these two wires are terminated together. The instructions to convert a 4-prong appliance to a 3-prong are at the bottom of the page in the link I provided.
NOTE: If this is a new dryer, keep in mind, some REQUIRE a 4-prong plug even if you have a pre-existing 3 prong outlet. Read through your installation instructions that came with the appliance if in doubt. If this is the case, you will need to have a 4 wire outlet installed by a certified electrician.
If you have questions, please let me know. I hope this helps you.
Aug 02, 2009 | Dryers
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Hello, I have a Kenmore 80 Series. Washer and Dryer. Bought it from someone on Craigslist. How do I hook them up? Is there a manual any where out there?
Connect your hot and cold water pipes to the washer. Place the drain pipe into a sink or direct drain feed to your sewer system. Plug it into outlet. Dryer - plug it into your 220 line outlet. If the plug is not the same as your outlet you can find instructions on lline with pics on how to change a 3 prong plug to a 4 prong plug and so on...:)
Jun 07, 2009 | Kenmore Dryers
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Dryers Logo
100 people viewed this question
Top Dryers Experts
