Question about Sony Ericsson Z525a Cellular Phone
Screen for z525
The screens both main and outside for my 525 have power but don't display anything. I have rebooted the phone and it starts up with the proper sounds - you can call and receive calls but can't see anything on the screens
  • 83 Answers
THE RIBBON INSIDE THE PHONE MIGHT HAVE RIPPED...U MIGHT NEED A NEW PHONE
Posted on Feb 21, 2008
I was advised to check if my Acer Notebook runs in DOS Mode in response to my problem (monitor does not power up). I don't know how to determine this.
It means check if you see any display on your screen outside Windows. Like when you turn your pc on, usually, before it goes to Windows, you see the manufacturer's logo, in this case Acer. So if you see the Acer logo or anything on your screen before it loads Windows, then the problem may be with the video driver. If you don't see anything at all when you turn your pc on, most likely it's the screen or the lcd itself that's broken.
Jun 30, 2011 | Computers & Internet
Inside screen when black and the outside sreen was still working then it went black my phone still works like normal just the screens are black and i cant see anything
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
Apr 16, 2010 | Motorola Mobility RAZR2 V8 Cellular Phone
Inside screen is blank; keyboard and phone, outside screen all working fine. inside screen used to be able to be reset by closing and reopening but now nothing makes a difference. Have powered Off/On...
To help you with this problem, I want you to know that when a cellphone got fell or something done to phone,like you accidentally sit on it, the main problem will be make is lost in display or it will crack,you will not see anything but you can hear something like message tone and start-up tone, you can also receive calls. Don't be worry with that kind of problem. To tell you whats happening inside your phone is your LCD display connection is only misaligned or need to be replaced when it was crack. Get it to the nearest cellphone repair center to get cellphone to be open by a technician and probably they will do dismantling your phone and fix the problem.
Don't forget to rate this solution please..Thanks..:-)
Nov 08, 2009 | Cell Phones
My phone fell and now the screen is blank at first you could not see anything but you could hear when it rings now you don,t
To help you with this problem, I want you to know that when a cellphone got fell, the main problem will be make is lost in display,you will not see anything but you can hear something like message tone and start-up tone, you can also receive calls. Don't be worry with that kind of problem. To tell you whats happening inside your phone is your LCD of display connection is only misaligned. Get it to the nearest cellphone repair center to get cellphone to be open by a technician and probably they will do dismantling your phone and fix the problem. Hope this could help. Don't forget to say thanks..:-)
Oct 25, 2009 | Nokia 2610 Cellular Phone
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
Logo stays on outside display window of cell phone
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself. I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Jun 28, 2007 | Motorola Mobility RAZR V3
My phone displays a white main screen
My Solution: Heat it up by just sitting on it or holding it in your hands// Take the battery out and back in/ Try keeping the battery out of it for a full day
My Story :) My mom dropped the phone in the dishes because she was drunk haha, I quickly took out the battery, but when the next day came by I looked at the phone and saw the same problem everyone here has. I kept replacing the battery on the hope it would just magically fix itself. Now 2 days from when it dropped in water, I kept flipping it, replaced the battery again (just taking it out and back in) after I sat on it a while, possibly the heat somehow helped it to work again.. I'm amazed it works haha, it was in the water fully submerged for half a min when I had to snatch it out of the dishes But, it is most likely that I took the battery out, the battery is the thing that ruins electronics, just remember to take it out if you drop it in water. Good luck. If worst comes to worst and your going to buy a new phone, maybe try using a blow dryer on it for a little bit **or just do this in the first place**
Jun 28, 2007 | LG VX8300 Cellular Phone
Sony Ericsson Z525a Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
