Question about KitchenAid 24 in. KUDP01IL Stainless Steel Free-standing Dishwasher
My kitchenaid dishwasher is not cleaning the dishes. I have cleaned the sprayers and screen.
  • 572 Answers
Check the chopper assembly
Posted on Feb 06, 2010
The water supply arm for middle sprayer is not held in place by clip that is attached to bottom of dish rack. Does not meet up with water outlet on back of washer and also impedes movement of sprayer arm....
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 11, 2011 | KitchenAid KUDS40CVSS Builtin Dishwasher
Our newer dishwasher does not clean the dishes presently. The water heats up, and drains properly, but I noticed the sprayer nozzles are not spinning when I open the dishwasher.
Try manually rotating the spray arm. Check the orifices & clean if clogged.
After loading the dishes check every time before closing the door for free rotation of the spray arm.
Apr 01, 2010 | KitchenAid Architect? II U SERIES KUDS03ST...
Top rack of dishes are not getting cleaned
sprayer could be clogged due to hard water build up. www.dishwasherfilter.com sells a product that will help clean out your dishwasher and prevent the problem in the future.
Feb 28, 2010 | KitchenAid Dishwashers
The water sprayers are not working and their is food still on the dishes...
he spray arms are probably clogged with food particles see if you can clen the holes in the arms..Then purchase a bottle of dishwasher cleaner form your local supermarket it works great and cleans all the **** outta your machine make sure you run hot water from tap closest to machine and use it in an empty dishwasher.Follow all instructions on bottle you will be amazed at how clean your dishes will come out with the first wash after the cleaning..cost per bottle is about 8.00
Jan 23, 2010 | KitchenAid KUDS03FTPA Built-in Dishwasher
Top rack whisperquiet dishwasher no water
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8573754.pdf
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
My Kitchen Aid KUDI01FLBL3 is not cleaning my
Most likely there is debris at the pump impeller. This model has a problem with debris and grease accumulation at the pump inlet. I have no idea how it gets past the screen but it does. Remove the transfer tube on the back wall, the lower sprayer, and screen assembly. Clean out the debris and reverse installation.
Sep 16, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
My whisper quiet dishwasher is not cleaning the top rack dishes
I'm having the same problem. Did some testing and found that the sprayer on the top rack is not even moving and hence not getting any water. Not sure what to do.
Sep 07, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Jan 18, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Dish washer does not clean didhes on the second level
I had a similar poblem with my Kitchenaid dishwasher( piece of overpriced poop) I had to replace the empeller /chopper unit that chops debris when washing. It was bent to the point where it would not turn & power the pumping to the top sprayer. Once I replaced it it worked, until it broke again. Do yourself a favor & NEVER buy a Kitchenaid. cheers Billy D
Mar 08, 2008 | Dishwashers
KitchenAid 24 in. KUDP01IL Stainless Steel Free-standing Dishwasher Logo
241 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
