Question about Xerox Phaser 8550DP Printer
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
    President:
  • 2,072 Answers
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  6. lines on print. There's are three lines on picture - 8500-wiper-blade-clean.jpg
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Posted on Feb 05, 2010
  • Rick Kasper Feb 05, 2010
    How to enter Jet Sub.
    To enable the Jet Substitution mode:
      button.
    4. If necessary, select [Print Light Stripes Test] to make a Light
      Stripes Test print that shows any weak or missing jet and its jet
      number.
    5. Press the [Up] or [Down] arrow button to select [Jet Substitution Mode], and then press the [OK] button.
    6. Press the [Up] or [Down] arrow button to select the color for the
      weak or missing jet, and then press the [OK] button to select the color.
    7. Press the [Up] or [Down] arrow button to select the number of the
      weak or missing jet (1 to 309), and then press the [OK] button to
      confirm the selection.
      NOTE: If necessary, press the [Up] or [Down] arrow button to select [Save Change and Select Another Jet] to substitute more jets.
    8. Press the [Up] or [Down] arrow button to select [Save Change and Exit] and then press the [OK] button to complete the procedure.
    To disable the Jet Substitution mode:
      button.
    4. Press the [Up] or [Down] arrow button to select [Jet Substitution Mode], and then press the [OK] button.
    5. Press the [Up] or [Down] arrow button to select [Turn Jet Substitution Mode Off], and then press the [OK] button.
    6. NOTE: Any saved and stored jobs on the printer’s hard
      drive (if the hard drive option is present and enabled by the printer’s
      feature set on a Phaser 8550) will need to be resubmitted to the hard
      drive to print correctly while Jet Substitution is enabled.
I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the seco
Is it prints or copies or both? If it's copies, clean the document feeder glass - small strip. What make/model? Laser? If laser, check the fuser roller
Nov 29, 2014 | Office Equipment & Supplies
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
Vertical line from document feeder
there is probably a dirt spot on the scanner glass where the document feeds in. try cleaning the thin glass under the document feed cover.
Apr 24, 2009 | HP Officejet J5780 All-In-One Printer
Faint one inch wide line appears at the same time, every time.
We've seen this problem in our shop. The document is "timing out" and the gap is where it restarts. You have to set the print manager to wait to print until the document is finished processing. Any large print will do the same thing. Try "pausing" the printer on your computer, then execute the "print" command in Photoshop, then go back to the printer control panel and "un-pausing" the printer.
Apr 06, 2009 | Epson Stylus Pro 9800 InkJet Printer
Printer cuts off top 1 inch of PDF document
Go to the printer properties and try setting it up with border less printing.
Cheers
May 23, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lines coming down from the top of screen
Those lines are beaming in from the planet Alenod. For the moment you'll only be annoyed by those lines. But when those lines finally expand the entire surface of your screen you and everything in your viewing area will vaporize. Gosh, If I were you I'd chunk it as quickly as possible and buy a 47" Vizio! They're on sell at Sams! Pleeze hurry!!
Mar 05, 2008 | Televison & Video
Printing out thepictures
Try printing the picture from another program. Or with less resolution.
If that doesn't work, try reinstalling the printer and downloading the latest drivers from the HP website.
Feb 06, 2008 | HP DeskJet 920c InkJet Printer
Blue vertical lines
Yes...your light engine/optical block is shot... 1500 dollars.
Jan 25, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Print is missing along a one inch width patch for the entire lengh of mdocument
try a new toner cartridge
if it doesn't fix your problem then you willneed a new fuser
it is probably delaminated
Dec 22, 2007 | HP LaserJet 3055 All-In-One Printer
Xerox Phaser 8550DP Printer Logo
2,143 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
