Question about Kenmore 64802 Top Freezer Refrigerator
Water is "leaking" into the refigerator, seemingly from the freezer. There is an Ice-maker, but it's water supply has been turned off. I think it may have something to do with condensation, but there seems to be more water then that could explain.
  • 572 Answers
Ur drain is clogged
Posted on Feb 05, 2010
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
Ice build-up on the bottom of the freezer drawer
Water on the freezer floor has only two sources, 1) ice maker overflow/leak, or 2) defrost drain plugged. For the first you can turn off the ice maker and shut off the supply water for a few days to see if the problem recurs. If this is the problem determine if the water fill valve leaks or the ice maker is the problem and replace the offender. For the second, thaw out and clear all the ice, paying special attention to the drain located under the freezer (cooling) coil. Then clear the blockage from the drain tube. BE CAREFUL AND DO NOT USE WIRE OR SHARP ITEMS as this can pierce a hole in the drain requiring replacement, not something you want to do or pay for. A turkey baster and hot water are useful tools to flush out the blockage allowing water to drain freely into the defrost drain pan under the refrigerator.
Sep 12, 2014 | Refrigerators
Ice maker leaking into freezer
4aef633b-7f84-436d-908c-19b020afc3d4.jpgThe problem youare having is a defective=> WR57X10051 Water Inlet Valve The valve is mechanically defective and allowing water to leak into your ice bin when the valve is off. I will be here if you have questions, Thanks Sea Breeze
May 15, 2013 | GE Refrigerators
Fridge and freezer are working just fine. But, I keep getting pools of water inside my fridge. These pools stay to the back of the fridge on all levels and they sometimes turn to ice. I notice ice layer...
Your defrost drain is most likely blocked with ice or sludge. Now when your refrigerator goes into defrost it pours into base of freezer or just anywhere it can to pool up. Click Here=> Leaking Refigerators, just what may be happening Click here also=> Leaking Refrigerator's? Please let me know if you still have questions, Thanks, Sea Breeze
Mar 19, 2011 | Whirlpool Refrigerators
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
Freezer not freezing, and leaking
If this unit has an ice maker and you noticed water leaking into the refigerator, I had a similar problem. The water turn off valve for the ice maker had a small piece of sand or grit lodged in it and stopped the valve from closing properly. So it could not turn of completely and the valve became increasingly more sloppy as the piece of sand was wedged in further. The solution was to replace the samll valve. An easy job for someone a bit handy.
If the water has frozen in the bottom of the freezer compartment the colliing port for the cold air may also be affected. Don't chip the ice out of the bottom, defrost it with pans of hot water.
Hope this helps
May 03, 2009 | Frigidaire Freezers
New water valve not filling the ice maker.
take the supply line to water valve and blow into it
you will feel it if it is clear if blocked remove tube
and clean
Apr 13, 2009 | Refrigerators
Water is leaking from freezer into lower compartment of kenmore
If you think it is the ice maker then shut down the water supply and see if the leak stops. Most likely though it is probably a blocked defrost drain.
Apr 09, 2009 | Refrigerators
ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Feb 14, 2008 | Sub-Zero 690 Side by Side Refrigerator
Kenmore 64802 Top Freezer Refrigerator Logo
150 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
